Is it possible to connect Netgear Mesh Satellite to AX4300
A84Gamer
Hey there,
I have the Netgear Nighthawk AX6 6-Stream AX4300 WiFi 6 Router.
Is it possible to connect a Nighthawk Mesh Satellite to it in order to extend my network in the same way a mesh network behaves?
Or is the AX4300 not designed to function as a mesh base station in the first place?  I don't want to simply use a range extender since it doesn't offer the same benefits of a mesh node.
Thanks!
1 hour ago, A84Gamer said:
Hey there,
Thanks!
The first bullet on the MS60-AX1800 Nighthawk Mesh WiFi web page...
Quote
Only works with a Nighthawk Mesh WiFi 6 System (MK62 or MK63) sold separately.
Ah, good catch.
Thank you.
FYI for anyone else that has this question. I contacted Netgear and the advisor said you can use something like this extend it as a mesh:
https://www.netgear.com/home/products/networking/wifi-range-extenders/EAX80.aspx
It's safe to assume that the router you are connecting the extender to must be Wi-Fi 6, so keep an eye out for that.
Thanks again.
