Doesnt power up
Go to solution Solved by Venomz1337,
How would I short the pins?
By putting a screwdriver in between them.
Ive recently built a new pc, only thing missing is a GPU, but I wanted to make sure everything works that I have now, my Z87-A has a green LED that comes on when the AX860 PSU is turned on but I go to press the power button and nothing happens, the front fans spin for a split second but I think thats due to them being connected straight to the PSU via molex. Any help? could it be the power button itself?
http://imgur.com/16LsAeh
Also in the picture I have no RAM installed, but I took 2x2GB sticks from my current pc and installed them.
Fixed it guys, thanks for the help.
https://linustechtips.com/topic/120598-doesnt-power-up/
My Gaming Rig;  Motherboard - ASUS Maximus VI Hero | CPU - Intel i5 4670k @4.5Ghz 1.25v | GPU - GIGABYTE GTX 980 @Stock | RAM -  16GB Corsair Vengeance @1866Mhz | CPU Cooler - Corsair H100i | Storage #1 - Samsung 840 Basic 250GB SSD | Storage #2 - Sandisk II 480GB SSD | Storage #3 - 2TB 7200rpm 64mb HDDPSU - Corsair HX750 | Case - Fractal Design R4 |
https://linustechtips.com/topic/120598-doesnt-power-up/#findComment-1606112
This may be differerent with some motherboards. I am not exactly sure if its normalised. Consult your manual.
You need to touch the power button pins. Basically you do the same thing that power button does, without the power button :)
My modded Air 540 build
https://linustechtips.com/topic/120598-doesnt-power-up/#findComment-1606125
