Budget (including currency): Dont really have a set budget just looking to spend roughly £1500 give or take
Country: England
Games, programs or workloads that it will be used for: GTA, Streaming, Rocket league, editing/rendering
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): so I actually have all the parts picked out and the peripherals don’t come under my pc budget, just need some help for some parts I could swap out to get the best performance for the same price. PS . Never built a pc before so wasn’t really sure what to go for.
MOTHERBOARD: MSI MPG X570 gaming edge
CASE: Corsair SPEC-DELTA
CPU: Ryzen 7 3700x
CPU COOLER: GameMax iceberg 240mm radiator
RAM: Corsair vengeance RGB PRO 3200Mhz 2x8GB
GPU: Nvidia RTX 2060 Super
SSD: Sabrent rocket 256 m.2
HDD: Seagate barracuda 1TB
PSU: 850W 80+ Gold
PERIPHERALS:
MONITOR: Double monitor 144hz 1ms 1080p
KEYBOARD: HyperX alloy origins series
MOUSE: Razer viper
LEDS
https://linustechtips.com/topic/1205283-first-pc-build/
1500 including monitor and peripherals?
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
https://linustechtips.com/topic/1205283-first-pc-build/#findComment-13684600
PCPartPicker Part List
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor  (£279.98 @ Amazon UK)
CPU Cooler: Noctua NH-U12S chromax.black 55 CFM CPU Cooler  (£64.98 @ Amazon UK)
Motherboard: MSI B450 TOMAHAWK MAX ATX AM4 Motherboard  (£121.70 @ Amazon UK)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  (£64.98 @ Amazon UK)
Storage: Crucial P1 1 TB M.2-2280 NVME Solid State Drive  (£101.98 @ Amazon UK)
Video Card: Gigabyte GeForce RTX 2070 8 GB WINDFORCE 2X Video Card  (£409.98 @ Amazon UK)
Case: Corsair SPEC-DELTA RGB ATX Mid Tower Case  (£69.98 @ Amazon UK)
Power Supply: EVGA G5 750 W 80+ Gold Certified Fully Modular ATX Power Supply  (£111.94 @ More Computers)
Monitor: Samsung LC27JG50QQNZA 27.0" 2560x1440 144 Hz Monitor  (£296.20 @ More Computers)
Keyboard: Kingston HyperX Alloy Origins Wired Gaming Keyboard  (£79.99)
Mouse: Razer Viper Wired Optical Mouse  (£79.99)
Total: £1681.70
Generated by PCPartPicker 2020-06-06 02:35 BST+0100
kept some of the things you said, changed a couple things to get a better gpu
CPU: AMD 3600X
GPU: Nvidia 3070 (planned)
motherboard: MSI B500-A PRO
memory: G Skill Ripjaws V 2x8 GB 3600Mhz CL16
PSU: EVGA B3 650@
Case: NZXT H510
wireless network adapter: intel ax200
https://linustechtips.com/topic/1205283-first-pc-build/#findComment-13684640
Went with a 3600 so I could fit in a 2080 Super (currently the best GPU barring the unreasonably priced 2080 ti)
Feel free to swap out the case and peripherals. I recommend those because I love the smaller case, I love Cherry MX Blues, and I think the Harpoon RGB is a great, simple mouse and you don't need to spend more to get a good experience. If you DO want to spend more on a mouse, I'd save up for an MX Master 3 - probably the best mouse ever made, if the MX Master 1 is anything to judge by.
https://linustechtips.com/topic/1205283-first-pc-build/#findComment-13684650
Good choices overall but I disagree with allocating under 30% of your budget to the GPU in a gaming PC where that's responsible for the bulk of the performance - within reason...
https://linustechtips.com/topic/1205283-first-pc-build/#findComment-13684659
Also this monitor has no Freesync.
https://linustechtips.com/topic/1205283-first-pc-build/#findComment-13684662
true, i gave the monitor almost no thought i pretty much picked the cheapest one with the specs he wanted from a reputable manufacturer, i shouldn't have even listed one tbh
CPU: AMD 3600X
PSU: EVGA B3 650@
Case: NZXT H510
https://linustechtips.com/topic/1205283-first-pc-build/#findComment-13684665
He included it in his budget... We recommended mostly the same parts, I just dropped to a 3600 and got a 2080 super since he listed gaming before editing/rendering and managed to squeeze a 2080s... Up to OP, but I would get at least a 2070 super over the normal 2070.
https://linustechtips.com/topic/1205283-first-pc-build/#findComment-13684683
That board is terrible, and the psu is really bad value for money seeing as you only get a paltry 3 year warranty. No reason not to get the Mortar MAX or wait for B550. He can afford to get a psu such as the SuperFlower Leadex III 750W with a £1500 budget.
The 2070 Super is also better value if going with an Nvidia gpu. Saves around £200 for only about 10% average difference in performance depending on the game.
https://linustechtips.com/topic/1205283-first-pc-build/#findComment-13687886
