Budget (including currency): up to 2000 € + monitor (more budget for the monitor)
Country: Italy
Games, programs or workloads that it will be used for: used for gaming, planning for demanding games.
PCPartPicker Part List
CPU: *AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor  (€367.99 @ Alternate Italia) ---->on amazon italia at 300€
CPU Cooler: *Noctua NH-D15 CHROMAX.BLACK 82.52 CFM CPU Cooler  (€99.90 @ Amazon Italia)
Motherboard: *MSI B450M MORTAR MAX Micro ATX AM4 Motherboard  (€131.41 @ Amazon Italia)
Memory: *Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  (€85.36 @ Amazon Italia)
Storage: *Samsung 970 Evo Plus 1 TB M.2-2280 NVME Solid State Drive  (€209.89 @ Amazon Italia)
Video Card: Asus GeForce RTX 2080 SUPER 8 GB DUAL EVO OC Video Card  (€807.00 @ Amazon Italia)
Case: *NZXT H710 ATX Mid Tower Case  (€150.53 @ Amazon Italia)
Power Supply: EVGA SuperNOVA 650 G2, 80+ GOLD 650W
Keyboard: something functional, durable and not too flashy?
Monitor: 1440p 144hz, i found This on amazon but i don't really know how to choose one
notes:
The case has a front panel USB 3.2 Gen 2 Type C port that the MSI B450M MORTAR MAX can't handle, should i change motherboard?
Dont know if a 550w power supply will do, and 650w is priced the same as the 750w, for that reason i went with the 750w.
are there any problems with this build or something i should change?
Ty for the help
https://linustechtips.com/topic/1205016-help-with-a-build/
Change the case with a Fractal Design Meshify C or Meshify S2 or a Cooler Master H500M. NZXT cases are a fire hazard.
"Tolerance is the lube that helps the dildo of dysfunction slip into the ass of a civilized society" - Plato 427-347 BC
"Tolerance and apathy are the last virtues of a dying society" - Aristotle 384-322 BC
"Hope is the first step on the road to disappointment" - Lebiniz 1st of July 1646 - 14th of November 1716
https://linustechtips.com/topic/1205016-help-with-a-build/#findComment-13682532
Since you are going for a high-end aftermarket cooler, are you planning on overclocking or need silent cooling performance, if not then something like this will work great (the included Ryzen coolers are good although a bit noisy):
https://www.amazon.it/DEEP-COOL-GAMMAXX-Ventola-Aggiornata/dp/B082DZ8184/ref=sr_1_8?__mk_it_IT=ÅMÅŽÕÑ&crid=3S453IY6H5LL9&dchild=1&keywords=deepcool+gammax&qid=1591366605&sprefix=deepcool+ga%2Caps%2C248&sr=8-8
Would recommend upgrading to a 3800X if the price is the same or slightly more expensive since you will get better performance, a better included cooler, better overclocking potential, etc:
https://www.amazon.it/AMD-Ryzen-7-3800X-Processori/dp/B07SXMZLPJ/ref=sr_1_1?__mk_it_IT=ÅMÅŽÕÑ&dchild=1&keywords=amd+ryzen+7+3800x&qid=1591366445&sr=8-1
Hope this information post was helpful  ?,
        @Boomwebsearch
https://linustechtips.com/topic/1205016-help-with-a-build/#findComment-13682549
update
going for the Fractal Design Meshify C case, it come with 2 fans(1 front, 1 rear), should i buy more?
the case have max psu length of 175mm but the EVGA SuperNOVA 750 is 180mm and should not fit, so i'm powering it down to 650w(that is 165mm)
2 hours ago, JJCooper_ said:
you probably should ditch B450 and get an X570 board. Its overall a better chipset.
dropped the b450 for the asus x570 plus with wifi
i don't plan to overclock in the short term, but i probably will try in a few month and the more silent it is the better
switch out 3700x for 3800x --->its only 30€ more
here is the new plan.
CPU: AMD Ryzen 7 3800X 3.9 GHz 8-Core Processor  (€331.90 @ Amazon Italia)
Motherboard: Asus TUF GAMING X570-PLUS (WI-FI) ATX AM4 Motherboard  (€239.00 @ Amazon Italia)
Case: Fractal Design Meshify C ATX Mid Tower Case  (€102.65 @ Amazon Italia)
Total: €1875.70
Generated by PCPartPicker 2020-06-05 18:20 CEST+0200
psu:[url=https://www.amazon.it/EVGA-SuperNOVA-automatico-Alimentazione-Alimentazione-220-G2-0650-Y2/dp/B014JNH3BC/ref=sr_1_3?__mk_it_IT=ÅMÅŽÕÑ&dchild=1&keywords=Seasonic+650W+80+Plus+Titanium&qid=1591269626&quartzVehicle=5-104&replacementKeywords=seasonic+650w+plus+titanium&sr=8-3] evga supernova 650w [/url] 130€
total 2k €
https://linustechtips.com/topic/1205016-help-with-a-build/#findComment-13682902
The 3800X is 35 Euros more expensive. Not worth it.
https://linustechtips.com/topic/1205016-help-with-a-build/#findComment-13683138
1 hour ago, Sadaweya said:
update
Total: €1875.70
total 2k €
Some suggestions.
Stick with the 3700X. The 3800X isn't worth the extra 35 Euros.
You could easily go with a cheaper air cooler such as the Arctic Freezer 34 esports duo.
I would suggest waiting until June 16th if possible for B550. If going X570 then the MSI X570 Tomahawk is better than any at the 230 Euro price point. It is due out any day now (Already people in the UK with it).
A Sabrent Rocket 1TB is cheaper than the 970 EVO.
https://it.pcpartpicker.com/product/N7zkcf/sabrent-1-tb-m2-2280-solid-state-drive-sb-rocket-1tb
Maybe get a better version of the 2080 Super. The Gigabyte Windforce is a bit cheaper.
https://linustechtips.com/topic/1205016-help-with-a-build/#findComment-13683179
3700x if you buy any aftermarket cooler since 3700x is same chip if you enable PBO, which you should do since OCing Ryzen is pointless since PBO does it better. :)
Zen-III-X8-5900X (Gamestation 5)
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Ryzen 5 3600, 6-cores, 12-threads, 4.2/4.2GHz, 35,3MB cache (T.S.M.C. 7nm FinFET) / CPU: AMD Ryzen 9 5900X, 12(8)-cores, 24(16)-threads, 4.5/4.8GHz, 70.5MB(68,35MB) cache (T.S.M.C. 7nm FinFET) / Display: HP 24" L2445w (64Hz OC) 1920x1200 / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: ASUS Radeon RX 6600 XT DUAL OC RDNA2 32CUs @2.6GHz 10.6 TFLOPS (T.S.M.C. 7nm FinFET) R.ID (NimeZ drivers) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: ASRock B450M Pro4, Socket-AM4 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W / RAM A1 & B1: G.SKILL DDR4-3600MHz CL18-20-21-39-60-1T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: HyperX DDR4-3600MHz CL16-18-19-37-85-1T "SK Hynix 8Gbit CJR" (2x16GB) / Operating System: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Western Digital My Passport 2.5" 2TB HDD / Storage 4: Western Digital Elements Desktop 2TB HDD / Storage 5: Kingston A2000 1TB M.2 NVME SSD / Wi-fi & Bluetooth: ASUS PCE-AC55BT Wireless Adapter (Intel)
 Lake-V-X6-10600 (Gaming PC)
R23 score MC: 9190pts | R23 score SC: 1302pts
R20 score MC: 3529cb | R20 score SC: 506cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: Intel Core i5-10600(ASUS Performance Enhancement), 6-cores, 12-threads, 4.4/4.8GHz, 13,7MB cache (Intel 14nm++ FinFET) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: Gigabyte Radeon RX Vega 56 Gaming OC GCN5 56CUs @1.7GHz 12.19 TFLOPS (Samsung 14nm FinFET) R.ID (NimeZ drivers) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: ASUS PRIME B460 PLUS, Socket-LGA1200 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W / RAM A1 & B1: HyperX DDR4-2666MHz CL13-15-15-30-45-2T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: Juhor DDR4-3200MHz CL16-20-20-38-72-2T "SK Hynix 8Gbit MFR" (2x16GB) / Operating System: Windows 10 Home / Sound: Zombee Z300 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Seagate® Barracuda 2TB HDD / Storage 4: Seagate® Desktop 2TB SSHD / Storage 5: Crucial P1 1000GB M.2 SSD/ Storage 6: Western Digital WD7500BPKX 2.5" HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter (Qualcomm Atheros)
Vishera-X8-9370 | R20 score MC: 1476cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Case Fan VRM: SUNON MagLev KDE1209PTV3 92mm / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: AMD FX-8370 (Base: @4.4GHz | Turbo: @4.7GHz) Black Edition Eight-Core (Global Foundries 32nm) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: Gigabyte Radeon RX Vega 56 Gaming OC @1501MHz (Samsung 14nm FinFET) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: MSI 970 GAMING, Socket-AM3+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W PSU / RAM 1, 2, 3 & 4: Corsair Vengeance DDR3-1866MHz CL8-10-10-28-37-2T (4x4GB) 16.38GB / Operating System 1: Windows 10 Home / Sound: Zombee Z300 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Seagate® Barracuda 2TB HDD / Storage 3: Seagate® Desktop 2TB SSHD / Wi-fi: TP-Link TL-WN951N 11n Wireless Adapter
Godavari-X4-880K | R20 score MC: 810cb
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 95w Thermal Solution / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Athlon X4 860K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / CPU: AMD Athlon X4 880K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / Display: HP 19" Flat Panel L1940 (75Hz) 1280x1024 / GPU: EVGA GeForce GTX 960 SuperSC 2GB (T.S.M.C. 28nm) / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: MSI A78M-E45 V2, Socket-FM2+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W PSU / RAM 1, 2, 3 & 4: SK hynix DDR3-1866MHz CL9-10-11-27-40 (4x4GB) 16.38GB / Operating System 1: Ubuntu Gnome 16.04 LTS (Xenial Xerus) / Operating System 2: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Western Digital My Passport 2.5" 2TB HDD / Storage 3: Western Digital Elements Desktop 2TB HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter
Acer Aspire 7738G custom (changed CPU, GPU & Storage)
CPU: Intel Core 2 Duo P8600, 2-cores, 2-threads, 2.4GHz, 3MB cache (Intel 45nm) / GPU: ATi Radeon HD 4570 515MB DDR2 (T.S.M.C. 55nm) / RAM: DDR2-1066MHz CL7-7-7-20-1T (2x2GB) / Operating System: Windows 10 Home / Storage: Crucial BX500 480GB 3D NAND SATA 2.5" SSD
Complete portable device SoC history:
Apple A4 - Apple iPod touch (4th generation)
Apple A5 - Apple iPod touch (5th generation)
Apple A9 - Apple iPhone 6s Plus
HiSilicon Kirin 810 (T.S.M.C. 7nm) - Huawei P40 Lite / Huawei nova 7i
Mediatek Dimensity 700 (T.S.M.C 7nm) - Cherry Mobile Aqua S10 Pro 5G
Mediatek MT2601 (T.S.M.C 28nm) - TicWatch E
Mediatek MT6580 (T.S.M.C 28nm) - TECNO Spark 2 (1GB RAM)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (orange)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (yellow)
Mediatek MT6735 (T.S.M.C 28nm) - HMD Nokia 3 Dual SIM
Mediatek MT6737 (T.S.M.C 28nm) - Cherry Mobile Flare S6
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (blue)
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (gold)
Mediatek MT6750 (T.S.M.C 28nm) - honor 6C Pro / honor V9 Play
Mediatek MT6765 (T.S.M.C 12nm) - TECNO Pouvoir 3 Plus
Mediatek MT6797D (T.S.M.C 20nm) - my|phone Brown Tab 1
Qualcomm MSM8926 (T.S.M.C. 28nm) - Microsoft Lumia 640 LTE
Qualcomm MSM8974AA (T.S.M.C. 28nm) - Blackberry Passport
Qualcomm SDM710 (Samsung 10nm) - Oppo Realme 3 Pro
https://linustechtips.com/topic/1205016-help-with-a-build/#findComment-13683230
Well you will need to buy aftermarket case fans for the Fractal Case. The Fractal Design Meshify S2 has a PSU length of 300mm and CM H500M a length of 200mm if you don't want to "power down" on your PSU.
https://linustechtips.com/topic/1205016-help-with-a-build/#findComment-13683260
back to the 3700k
the 3700x have a stock wraith prism, is that fine or do i need to buy a cooler?
https://www.amazon.it/AMD-Ryzen-7-3700X-Processori/dp/B07SXMZLPK/ref=sr_1_1?__mk_it_IT=ÅMÅŽÕÑ&dchild=1&keywords=3700x&qid=1591385901&sr=8-1
no problem waiting till june 16th, the gpu won't arrive until the 20th
going for the 60 less bucks
the gigabyte windforce is 810€ now
i have another question, are the extra 200€ for the 2080super worth over the 2070super?
ok
thanks for the help
https://linustechtips.com/topic/1205016-help-with-a-build/#findComment-13683691
2 hours ago, Sadaweya said:
back to the 3700k
ok
thanks for the help
The stock cooler is ok, but if you find it too noisy then just buy a cheapish air cooler like the Arctic one, or a Gelid Phantom/Black etc.
https://it.pcpartpicker.com/product/dmXnTW/arctic-freezer-34-esports-duo-cpu-cooler-acfre00060a
https://it.pcpartpicker.com/product/J7ZzK8/arctic-freezer-34-esports-duo-cpu-cooler-acfre00074a
https://it.pcpartpicker.com/product/6C4BD3/gelid-solutions-phantom-cpu-cooler-cc-phantom-01-a
https://it.pcpartpicker.com/product/jmmFf7/gelid-solutions-phantom-black-cpu-cooler-cc-phantom-black-01-a
I personally don't think the 2080 Super is worth an extra 200 Euros. A 5700XT is even better value if you don't mind an AMD gpu and performs well at 1440p. Not sure what is available in stock, but the Gigabyte Gaming OC, Sapphire Pulse/Nitro, Powercolor Red Dragon/Red Devil and MSI Gaming X are all good.
https://linustechtips.com/topic/1205016-help-with-a-build/#findComment-13684251
CPU: *AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor  (€302.89 @ Amazon Italia)
going with stock cooler for now,
Motherboard: MSI MAG X570 TOMAHAWK WIFI ATX AM4 Motherboard  (€316.00)
or  a b550 if it came in a reasonable time
Memory: *Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  (€91.24 @ Amazon Italia)
Storage: Sabrent Rocket 1 TB M.2-2280 NVME Solid State Drive  (€149.99 @ Amazon Italia)
Video Card: Gigabyte GeForce RTX 2070 SUPER 8 GB GAMING OC 3X Video Card  (€585.70 @ Amazon Italia)
Power Supply: EVGA SuperNOVA G2 650 W 80+ Gold Certified Fully Modular ATX Power Supply  (€133.00)
Total: €1681.47
Generated by PCPartPicker 2020-06-06 14:40 CEST+0200
https://linustechtips.com/topic/1205016-help-with-a-build/#findComment-13685922
