I am a researcher and planning to upgrade from a 6 year old Lenovo y50-70 laptop.
I will be using this laptop primarily for programming (C++, MATLAB, R and some other statistical software), word processing  and multimedia (no gaming).
Most of the software I use are compatible with MacOS too .
I want a robust, thin and light laptop with good battery life. I want screen to be vibrant and should cover maximum Adobe RGB color space.
As I will be using the laptop for CPU intensive tasks, I want an i7 processor with more than 4 cores (for parallel processing) and high frequency.
I prefer aspect ratio other than 16:9 as I need more vertical space on screen. Screen size should be greater than 14 inch.
Some brands I am considering to buy: Lenovo Thinkpad, Dell Precision, Microsoft Surface, Apple Macbook Pro
Pleas suggest some good laptop models.
PS: Is Apple going to launch Macbook pro 14 inch in next 1 year?
https://linustechtips.com/topic/1204841-laptop-buying-guide-for-cpu-intensive-task/
get a g14 or g15 with a r9
I7 are slow compared to a ryzen 7 or 9. that is also some 2017 laptop requirements
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
I suggest the rog zephryus g14. it has the ryzen 4900hs or the xmg apex 15 with a full on desktop 3950 with 16 cores
when it comes to anything other than gameing intel is usally slower
these may be bigger and more expensive but very good for production
for cheaper try and find something with a ryzen 7
