I bought a Valve Index headset and installed everything properly. Using a RTX 2080ti and a water cooled and slightly overclocked i9-7960x I have more than enough for simple VR games on low settings.
The rendering is smooth in every game, even Half Life Alyx at Ultra settings.
However, there are these very distinct frame skippings occurring randomly with around 8-10 seconds intervals. They doesn't seem to be related to any CPU bottlenecks or GPU problems, both being at 12% and 40% in Steam Home.
I've tried seeing any correlation between software jumping up in use in the activity monitor when the spike occurs, but nothing shows. I've tried all possible combination of settings in the NVidia settings and no luck.
Looking at the advance frame timing graph in SteamVR I can see that the "WaitGetPoses" drops entirely when the spike goes up for everything else. The "WaitGetPoses" has to do with the position of the headset, but I can't figure out if this is how the computer and software is handling and sending that data (out) or if this is before the computer and software handles the data (in).
I've looked around and seen that some Unity developers seem to have similar problems, but there are no consistent answers to any of this while the "reinstall windows 10" standard answers are the most common non-answers. I think that figuring out why this thing is happening is preferable before jumping to a solution.
Anyone else who experience this thing?
AfterTrack3.thumb.png.8d43e7850f1c6df1eedbadd04c87ea8b.pngAfterTrack.thumb.png.eaebc096757cbbb2f55db963913457ac.png
https://linustechtips.com/topic/1204453-vr-random-frame-skips/
SIMPLE VR ON LOW SETTINGS?!?! that is one of the best possible cards you can find.
Regarding your problem it is likely to be be just a driver issue, or windows 10 being on crack
Main PC [The Rig of Theseus]:
CPU: i5-8600K @ 5.0 GHz | GPU: GTX 1660 | RAM: 16 GB DDR4 3000 MHz | Case: Lian Li PC-O11 Dynamic | PSU: Corsair RM 650i | SSD: Corsair MP510 480 GB |  HDD: 2x 6 TB WD Red| Motherboard: Gigabyte Z390 Aorus Pro | OS: Windows 11 Pro for Workstations
Secondary PC [Why did I bother]:
CPU: AMD Athlon 3000G | GPU: Vega 3 iGPU | RAM: 8 GB DDR4 3000 MHz | Case: Corsair 88R | PSU: Corsair VS 650 | SSD: WD Green M.2 SATA 120 GB | Motherboard: MSI A320M-A PRO MAX | OS: Windows 11 Pro for Workstations
Server [Solution in search of a problem]:
Model: HP DL360e Gen8 | CPU: 1x Xeon E5-2430L v1 | RAM: 12 GB DDR3 1066 MHz | SSD: Kingston A400 120 GB | OS: VMware ESXi 7
Server 2 electric boogaloo [A waste of electricity]:
Model: intel NUC NUC5CPYH | CPU: Celeron N3050 | RAM: 2GB DDR3L 1600 MHz | SSD: Kingston UV400 120 GB | OS: Debian Bullseye
Laptop:
Model: ThinkBook 14 Gen 2 AMD | CPU: Ryzen 7 4700U | RAM: 16 GB DDR4 3200 MHz | OS: Windows 11 Pro
Photography:
Cameras:
Full Frame digital: Sony α7
APS-C digital: Sony α100
Medium Format Film: Kodak Junior SIX-20
35mm Film:
Lenses:
Sony SAL-1870 18-70mm ƒ/3.5-5.6
Sony SAL-75300 75-300mm ƒ/4.5-5.6
Meike MK-50mm ƒ/1.7
PSA: No, I didn't waste all that money on computers, (except the main one) my server cost $40, the intel NUC was my old PC (although then it had 8GB of ram, I gave the bigger stick of ram to a person who really needed it), my laptop is used and the second PC is really cheap.
I like tinkering with computers and have a personal hatred towards phones and everything they represent (I daily drive an iPhone 7, or a 6, depends on which one works that day)
https://linustechtips.com/topic/1204453-vr-random-frame-skips/#findComment-13677621
Yeah, which is my point. The card is one of the best cards and the processor isn't the worst for gaming and within a very simple rendered environment, like the grid/mountain loading screen for SteamVR, which gets the timing of the GPU down to 0,4, you still get these hiccups from "WaitGetPoses".
Since everyone supposedly are on the same drivers for SteamVR and Nvidia, it would be interesting to hear the frame timing others have. This is an issue that can be hard to spot when just casually playing, but it's glaring in slower things and if you notice a large purple spike in the in-headset graph it's that thing.
https://linustechtips.com/topic/1204453-vr-random-frame-skips/#findComment-13677649
