My brother is getting a used Canon 450D for his birthday. I know nothing about photography but want to get him some related gifts. This is his first DSLR so he doesn't have much gear for it. His fiance has mentioned he wants to start bird watching/space stuff. I'm more inclined to get him general purpose gear because it seems like he doesn't have a specific use for it yet.
Any advice would be greatly appreciated. I've already bought 2 batteries, and a memory card case. I plan to get him a few SDHC cards because all of his are SDXC.
https://linustechtips.com/topic/1204176-essential-equipment-for-beginner/
Isnt SDXC better than SDHC? Anyways
Maybe a good tripod if he wants to do space stuff?
Then maybe a camerabag, so he can take the camera anywhere etc?
Maybe instead of a bag a nice camera strap?
More advanced gifts would include maybe some filters, or even lenses, but lenses can be expensive and hard to pick.
My personal gift would be old soviet lenses, as those are dirt cheap, but they are really hard to get if you aren't in europe etc, and they can be a pain to pick out.
I only see your reply if you @ me.
As far as I can tell SDXC isn't compatible. It's was released 12 years ago.
I've tried to look at bags, not sure if most dslrs are the same size because nothing comes up when I search 450d camera bag.
I will look at those lenses but I'm in Canada so it might not pan out.
Thanks for the advice.
Aaah, gotcha. Yeah then sdhc will have to do.
Yeah camera bags have standard sizes, but the safest is to take the camera to the shop and try all the different bags, but kinda not possible with a gift yeah. Standard DSLR bags should work.
As far for the lenses, the camera uses Canon EF-S mount, maybe canon EF will also work? There are some cheap, like below 100$ canon lenses, so that could be an option.
As far for the soviet lenses? They can be quite a hassle, they require specific adaptors, usually M42 adaptor, and then you adapt that to m39.
Oh ok cool, thanks.
Maybe I'll just go with him and get a bag after his birthday. He is notorious for damaging stuff, so that'd be the priority.
I'll look into those canon lenses, the soviet ones seem a bit outta my comfort level. I'd rather just tell him about them and let him figure it out.
Thanks again.
EF do work with EF-s
so get a 75-300 III or III USM (faster better focus)
then if you still got more you'd want to spend look at yongonu 35 and 50mm fixed lenses. the 35 runs about 90$ and the 50 about 50$
that is capacity not speed. you are limted to SDHC on it
They aren't hard to get in the US it just takes time my helios 44 I ordered are looking like month-2 months
most bags are universal as most are similar in size
tripods can be a good starting item as well
I wouldn't worry about a fancy strap
Edited by GDRRiley
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
He wants to do some bird photography? A big lens is pretty expensive so he'd have to get one himself, but a ghillie suit and a ghillie cover would be handy for that kind of photography.
In a more general note, a monopod/tripod can be a good starter gift. If your budget stretches to it, you could also gift a lens. I don't know what kind of lens he's getting with his camera, but something like a 18-300mm lens is a very good general purpose lens. A magpul MS2 can also make a pretty good camera sling when paired with a tripod mount ring, that's what I personally use.
REMILIA Mk.IIIG CPU: Ryzen 7 5700X3D, Cooler: Gelid Sirocco (Arctic MX6), RAM: 4x 8Gb sticks of Patriot Viper Steel Series 3600 CL17, Mobo: AsRock X570 Taichi, GPU: Inno3D RTX 3080 iChill x4 10G, Storage: 1TB Intel 670p NVME SSD boot drive, a few 1TB and 512gb SATA/NVME SSDs for game storage, 6 hard drives:2-12 TB, PSU: Montech Century II 850W, Case: Silverstone FLP02, PCIE Cards: Cheap Chinese Marvell 88SE9215 4 port SATA card, Sonnet Allegro USB3.2 Card Monitors: ViewSonic Elite XG270QC (165hz, 1ms MPRT, 1440p, VA, Freesync PP, pneumatic stand), electriq 27qhd180i (IPS, 180hz, 1440p, 1Ms), iiyama G2530HSU-B (75Hz, Freesync, one in landscape, one in Portrait, all on pneumatic monitor stands).
Mic: iSK UPM-1 USB XLR interface with Neewer NW700, Audio: Sabaj A3 160W DAC/AMP + Wharfdale Diamond 220 + Mission MS6 Sub, Fiio K11 R2R DAC + Douk P5 (Toshiba Tubes), Sendy Peacock, Mouse: Glorious Model I, Keyboard: Glorious GMMK ISO with Mengmoda MMD Tactile (main) and Kailh Box Navy (Function keys), Tribosys 3203 brush lubed, Taihao Green forest caps.
I'd say for the 400-600$ you'd be better off with other glass like a 17-50F2.8 and then an 75-300
75-300 III/III USM will do okay for 80-150$ used/refurbished
that really isn't needed to start
It's just the versatility of a 18-300mm which I really like, especially if it's macro too. It can do both amateur bird photography and selfies if you so desire. Realistically all a beginner would need in their bag is one of these lenses and a fast 50. Sigma and Tamron (believe the tamron is a 18-400) make these lenses and they're $400 new, which is a bit expensive if you're starting out, but they're worth it imo.
If he wants to get into bird photography then a pair of decent-but-cheapish binoculars will help him find them (it's a lot easier to scan for wildlife than through the camera viewfinder, especially as you get your natural depth perception). I have a pair of Nikon Prostaff 7s, great binoculars for the price (~200 euro), waterproof, light, good colours.
Also, he'll want a tripod. Everybody thinks they don't need one, until they try taking photographs of things that are a long way away and can't get them in focus or sharp. Because they're not using a tripod and at those distances even a millimetre of camera movement is enough to make a bird jump halfway across the sensor.
AMD Ryzen 7800 X3D, MSI B650 Project Zero, Antec C5, Gigabyte RTX 4080 Super Aero
Nikon D500 | Nikon 300mm f/4 PF  | Nikon 200-500 f/5.6 | Nikon 50mm f/1.8 | Tamron 70-210 f/4 VCII | Sigma 10-20 f/3.5 | Nikon 17-55 f/2.8 | Tamron 90mm F2.8 SP Di VC USD Macro | Neewer 750II
Just now, iBabySlapper said:
It's just the versatility of a 18-300mm which I really like. It can do both amateur bird photography and selfies if you so desire. Realistically all a beginner would need in their bag is one of these lenses and a fast 50. Sigma and Tamron make these lenses and they're $400 new, which is a bit expensive if you're starting out, but they're worth it imo.
I've got an 18-135 and I love it but the issues is the the 18-300 doesn't seem to really zoom into 300mm due to focus breathing. you'd be better served by a normal fast zoom and then a cheap telli
I agree a 50mm and maybe a 35mm (if both are EF as there is 1.6x multiplier)
Doing wildlife stuff requires one to be *extremely* skilled with their camera. It's not something you can just go out and do right out of the gate and get good results. But there is one thing he can do and get great results right out of the gate, and that's night photography
I vote instead of buying him a sh*tty 70-300 that wouldn't net him great results anyway, get him a GREAT tripod. THIS HERE IS A STEAL:
https://www.bhphotovideo.com/c/product/802118853-USE/gitzo_g1027_mk2_sport_carbon.html
Gitzo tripods are the gold standard for professional photographers. I own 2 of them, a medium and a small one like the one linked above. Unless he needs something crazy tall, with this he'll never buy a tripod again in his life. And with a great tripod like this, he can do long exposures at night of the stars and of the city. Set him up for success.
Work Rigs - 2015 15" MBP | 2019 15" MBP | 2021 16" M1 Max MBP | Lenovo ThinkPad T490 |
AMD Ryzen 9 5900X  |  MSI B550 Gaming Plus  |  64GB G.SKILL 3200 CL16 4x8GB |  AMD Reference RX 6800  |  WD Black SN750 1TB NVMe  |  Corsair RM750  |  Corsair H115i RGB Pro XT  |  Corsair 4000D  |  Dell S2721DGF  |
Fun Rig - AMD Ryzen 5 5600X  |  MSI B550 Tomahawk  |  32GB G.SKILL 3600 CL16 4x8GB |  AMD Reference 6800XT  | Creative Sound Blaster Z  |  WD Black SN850 500GB NVMe  |  WD Black SN750 2TB NVMe  |  WD Blue 1TB SATA SSD  |  Corsair RM850x  |  Corsair H100i RGB Pro XT  |  Corsair 4000D  |  LG 27GP850  |
