Cheaper water cooled GPU?
Go to solution Solved by ThatOneRussian,
1 minute ago, Jordy123 said:
Do you have one you could suggest? Ideally as cheap as possible haha
https://www.ekwb.com/shop/ek-mlc-phoenix-240-radiator-core-module
Here it is. But, unfortunately I believe they no longer make any other parts of this modular design. Damn shame. Sorry!
Hi
I am building my first PC so looking for a GPU. My local computer store is selling this graphics card (https://www.gigabyte.com/au/Graphics-Card/GV-N2080AORUSX-WB-8GC#kf) as an open box, but new, for $750AUD ($510USD I think). It seems like a really good card and a great deal, however I don't feel confident about custom loop water-cooling. Is there something like a CPU AIO, but for GPU I can attach to cool it?
Thanks
https://linustechtips.com/topic/1203157-cheaper-water-cooled-gpu/
"God created war so that Americans would learn geography"
Could always buy a kit and just add your gpu to the loop. You'd have to do the building yourself though. hmm
2 minutes ago, _DeXTeR_ said:
this more in line of what the op is looking, but warning it does fit rtx card properly.. OP your will need to watch a YTV on how to mod the g12 for it to connect the gpu properly
This is exactly what I was thinking of haha! Thanks for the help! Cheap too
Yeah, dont forget the extra fittings you will need. The quick disconnect doesn't attach immediately to a gpu water cooler like yours.
If you send them an email they will sort you right out. They helped me a bunch
