Budget (including currency): $1000-$1500
Country: US
Games, programs or workloads that it will be used for: Mostly for work, running 2-3 monitors all day with multiple applications.  Would also like to be able to handle some light gaming, but not a priority.
Price/performance is most important to me, but also wanting to have nice aesthetics with some RGB thrown in, to have the custom look.
Definitely want to go AMD Ryzen , but i am open to any suggestions. Thanks for any help /advice
I havent built anything in about 10 years, so definitely not up on all the new tech, but have attempted a start below:
PCPartPicker Part List: https://pcpartpicker.com/list/jrgMYH
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  ($167.00 @ Newegg)
Memory: Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($129.99 @ Amazon)
Storage: Samsung 970 Evo 500 GB M.2-2280 NVME Solid State Drive  ($99.99 @ Amazon)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  ($54.99 @ Newegg)
Video Card: MSI GeForce GTX 1660 6 GB GAMING X Video Card  ($237.99 @ Best Buy)
Case: NZXT H510 Elite ATX Mid Tower Case  ($149.99 @ Best Buy)
Power Supply: Cooler Master MWE Gold 650 W 80+ Gold Certified Fully Modular ATX Power Supply  ($99.99 @ Best Buy)
Total: $939.94
Generated by PCPartPicker 2020-05-31 10:18 EDT-0400
https://linustechtips.com/topic/1202679-ryzen-workstation-build-help/
That actually looks like a good build.
I would go with the x variant for the processor, but that's just me
If you want to get best price-to-performance, i would go with radeon rx gpus
Here are some good keyboards and mice-
professional looking-https://www.logitechg.com/en-us/products/gaming-keyboards/g512-mechanical-gaming-keyboard.html  https://www.logitechg.com/en-us/products/gaming-mice/g203-prodigy-gaming-mouse.html
normal- https://www.razer.com/gaming-keyboards-keypads/razer-blackwidow  https://www.razer.com/gaming-mice/razer-basilisk
If you want wireless, go with logitech (but it is quite a bit more expensive)
Country: US
Total: $939.94
What kind of workstation do you need, are you just dealing with word documents and spreadsheets or are you doing video editing? That alone will be the deciding factor in a cpu. If the former then the 3600 is more that adequate, if the latter then you may want to consider a 3700X/3900X as more cores would be beneficial in that scenario, for GPU i’d really spend a few extra dollars and get a 1660 Super, its not that much more and yet its about 10-15% faster across the board on average.
Quote me or @TwilightRavens if you want me to see your reply. I may go inactive for a long time from time to time because I forget how to socialize, but I will be back... eventually.
Main Gaming PC
AMD Ryzen 9 5950X || AsRock X570 Taichi || G.Skill TridentZ Neo DDR4 3600MHz 2 x 16GB C16 1.35v || AMD Wraith Prism || Phanteks Enthoo Pro E-ATX || Gigabyte RTX 3080 Ti Gaming OC || Samsung 970 Evo 250GB NVME SSD & Samsung 980 Pro 2TB NVME & Crucial 960GB SATA III SSD || EVGA Supernova 750W Platinum PQ || Windows 10 Pro 22H2 x64 || Gigabyte M27Q 27" 170Hz 1440P & Acer 21.5” 1080p 75hz IPS || Logitech G213 Prodigy || Logitech G502 Hero
Laptop
AMD Ryzen 5 4600H with RadeonGraphics || ASUS TUF A15 ||  DDR4 3200MHz 2 x 8GB C22 1.2v || ASUS GeForce GTX 1650 4G GDDR6 || 512GB NVME M.2 SSD  ||  Ubuntu 22.04.1 (Jammy Jellyfish)
Thanks for your response.  Some awesome looking keyboards there, much appreciated :)
I am not doing much video editing, i mostly do tons of browser tabs as well as multiple applications running across 2-3 monitors.   Lots of information being constantly updated i need to pull real time.  Really appreciate your input!
Then really as many cores as you can afford, but really you should go with a 3700X, 3800X if you want slightly better boost clocks. 32GB of RAM should be fine but depending on just how much stuff you may want to try for 64GB, but that won’t be as important as at least 8 cores. 3900X if you can squeeze that into the budget, I have one and I love it.
Main Gaming PC
Laptop
What for? They can just enable PBO and it will boost to the 3600x speeds.
24 minutes ago, TarmacBeast2330 said:
Avoid Razer for any peripherals except the Huntsman TE and the Viper Mini.
Don't get Logitech for keyboards, the have non replaceable keycaps due to having a custom keyswitch stem. Their mice are fine, pretty good wireless technology,
For that price, get something like a Ducky One 2 TKL and a G305.
Guys, did you not realize he hasn't picked a motherboard?
You can pick your motherboard from this tierlist here.
Although, you may want to wait for the B550 board, which will be released in the 16th of June, for easier upgrades to the 4000 series.
Main Rig :
Ryzen 7 2700X | Powercolor Red Devil RX 580 8 GB | Gigabyte AB350M Gaming 3 | 16 GB TeamGroup Elite 2400MHz | Samsung 750 EVO 240 GB | HGST 7200 RPM 1 TB | Seasonic M12II EVO | CoolerMaster Q300L | Dell U2518D | Dell P2217H |
Laptop :
Thinkpad X230 | i5 3320M | 8 GB DDR3 | V-Gen 128 GB SSD |
He didn’t ask for one in the op, once decided on a cpu you should buy around that.
Main Gaming PC
Laptop
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor  ($274.49 @ Amazon)
Motherboard: MSI B450 TOMAHAWK MAX ATX AM4 Motherboard  ($114.99 @ Best Buy)
Memory: G.Skill Trident Z Neo 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($149.99 @ Newegg)
Storage: Crucial P1 1 TB M.2-2280 NVME Solid State Drive  ($128.99 @ Dell)
Video Card: MSI GeForce GTX 1660 SUPER 6 GB VENTUS XS OC Video Card  ($249.99 @ B&H)
Case: Fractal Design Meshify C ATX Mid Tower Case  ($99.98 @ Newegg)
Power Supply: SeaSonic FOCUS Gold 650 W 80+ Gold Certified Semi-modular ATX Power Supply  ($108.00)
Total: $1181.42
Generated by PCPartPicker 2020-05-31 11:15 EDT-0400
True, I did not bother to select motherboard yet as I was still on the fence about which CPU would be best, i just wanted to set up a basic list to hopefully get started in the right direction, i do think based on everyones responses so far I think i would be better off going with a slightly better CPU.  I also wanted to ensure the system has good WiFi so that was a factor for selecting motherboard as well ( or purchasing separately if necessary )
Total: $1181.42
hey thanks, this looks very close to what i am now thinking, unfortunately a few parts unavailable or crazy overpriced at the moment though ( power supply and mobo seem tough)
Okay so the Ryzen 7 3700x does seem like i can fit into my budget, and get better performace.  Here is first attempt at a parts list with the 7.  thanks everyone for your help so far.
PCPartPicker Part List: https://pcpartpicker.com/list/pHfTTC
Motherboard: Asus TUF GAMING X570-PLUS (WI-FI) ATX AM4 Motherboard  ($189.99 @ Best Buy)
Memory: Corsair Vengeance RGB Pro 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($154.99 @ Amazon)
Video Card: Gigabyte GeForce GTX 1660 SUPER 6 GB OC Video Card  ($239.99 @ B&H)
Power Supply: Corsair CXM 650 W 80+ Bronze Certified Semi-modular ATX Power Supply  ($94.99 @ Best Buy)
Total: $1259.42
Generated by PCPartPicker 2020-05-31 11:42 EDT-0400
The psu I listed is available from newegg.com for U.S. $99.99 plus shipping. It is vastly superior to a CXM. The provided link shows it in stock.
The memory I suggested is also showing in stock at newegg.com
Total: $1259.42
Also if you don’t need or plan to use PCI-E 4.0, you can step down to a B450/X470 and probably save some money, just be sure to look at the mobo tier list. No gpu’s on the market currently max out even Gen 3, only deciding factor would be for a gen 4 nvme.
Main Gaming PC
Laptop
Unfortunately on my end the psu is on "back order"  on new egg but yes, you are able to order it , just unsure of when it would be in stock. The motherboard , i am having trouble finding wifi units at fair pricing, which are in stock.   Thank you
Thank you very much for the information :) , i was originally leaning towards the b450 but proving difficult to find an available option with wifi at a price lower than the 570
Get a PCIe Wi-Fi card.
10 hours ago, akabrad1 said:
definitely an option, can save about $30 going with the MSI B450 and good wifi card.   rather than the 570 with wifi
Yeah, the X570 board with the best wifi you can buy is the X570 Taichi, but that’s also a flagship board and over $300. Not sure about the wifi on any others but either a pci-e card or a usb wifi card should be sufficient.
Main Gaming PC
Laptop
