39 minutes ago, VegetableStu said:
depends on the nature of the damage. the connection pinout for NVMe unfortunately reside on one side evenly. it's unlikely you've only managed to break the pads for the later half of the x4 connection
(ignore the NGSFF chart on the right, that's from another topic entirely)
EDIT: yeah i don't think there's a configuration of breakage where an M.2 would remain intact for operational purposes
Aww i was hoping that there was any hope haha. The damage was to the far end of the bigger side of the connections. I woulda liked that the if the smaller side was okay i woulda been happier.
https://linustechtips.com/topic/1202633-m2-aorus-gen4-help/#findComment-13663107
