Need Help Please. Intermittent 100% cpu usage.
Go to solution Solved by GoodEnough,
i know its pretty stupid, but try overclocking your cpu by just .050ghz or by .1ghz
I'm tearing my hair out trying to find out what is going on with my system.😢
Everything was fine up until i upgraded my M.2 to a Samsung NVME evo plus. I fresh installed windows onto the NVME and have no other HD connected.
The problem is i have intermittent times were my PC becomes unresponsive and lags. if i try to open a tab like task manager it will take 10 seconds to open. all commands take a few seconds to register. this issue stays for about 5 mins then goes away and back to normal operation.
The PC is completely unusable during this time.
I have noticed that when this happens, on idle, my cpu in windows task manager will be 100% but in other monitoring programs such as HWmonitor the cpu is only using about 30-40%.
I have reset bios to default with the latest f14 bios and downloaded all drivers from motherboard manufacturer website.
System Specs.
Gigabyte Gaming Aurus 7
Gigabyte 2080 ti gaming OC
1 tb 970 Nvme samsung evo plus
intel i7-8700k stock
16gb ddr4 3000 (xmp1)
corsair hx750i
windows 10 (latest updates)
https://linustechtips.com/topic/1202253-need-help-please-intermittent-100-cpu-usage/
12 minutes ago, ManDownUnder said:
Okay. im a newb when it comes to overclocking. so i just change the multiplier and keep everything on default? if so what am i changing it too?
tour going to want to set the frequency to 4.4ghz, after you do that run a full system scan with windows defender just in case.
21 minutes ago, 5x5 said:
Get rid of the viruses and malware on your system. That will resolve the issue.
I wish it was that simple. keep in mind, this started with a fresh install of windows on a new NVME no other HD connected.
Okay i overclocked to 4.7 on all cores. I noticed that the voltages VID #1-5 are bouncing all over the place not sure if thats normal or not.
if your going to oc to 4.7 make sure to keep an eye on temps, but you should be fine, voltage is the only thing that really affects temp
8th gen uses paste. He has to be very careful. Even 100MHz can raise temps by quite a bit.
@4.7 all cores max temp is 73-77 c under load in 3d mark test
Also windows defender all clear.
  • 4 weeks later...
