My laptop hotspot uses Microsoft wifi direct virtual adapter #2 on my laptop. hotspot works as normal when i enable hotspot. however when i off hotspot the ssid of the network still appears from another device like my phone (isnt it supposed to be off?) and furthermore the ssid changes from <hotspot name> to DIRECT<hotspot name>msGo? any one can advice i really need help on this i cant find help on google OR do you recommend me to contact microsoft? thank you very very much in advance.
Replace the fear of the unknown with curiosity!
https://linustechtips.com/topic/1202172-laptop-hotspot-suspicious-problems/
This sounds to me like your device has WIFI Direct turned on. The only way to turn this off afaik is through CMD.
Open Start, type: CMD
Right click CMD
Click Run as administrator
Type in at the prompt OR Copy and Paste these one at a time : (Hit enter after each)
netsh wlan stop hostednetwork
Then type:
netsh wlan set hostednetwork mode=disallow
Hit Enter
Exit then restart.
If someone has helped you out on the forum don't forget to give them a reaction to say thank you!
The only true wisdom is in knowing you know nothing. - Socrates
Please put as much effort into your question as you expect me to put into answering it.
