2 minutes ago, Hawkraider said:
I have a duel core amd a4 4020 and i want to pair it with a gtx 1650. Will i be able to play AAA titles without CPU bottleneck
the recommended processor for that gpu is a Intel Core i5-8400 6-Core 2.8GHz, but you should be able to just barely skip by depending on the game
https://linustechtips.com/topic/1201710-cpu-help-needed/#findComment-13655751
The recommended cpu for that gpu ?!
That is bull shit
An athlon 3000g would pair extremely nicely with no bottleneck with that GPU
Where did you get that from ?
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1201710-cpu-help-needed/#findComment-13655770
That is bull shit
https://www.game-debate.com/gpu/index.php?gid=4094&gid2=3876&compare=Nvidia GeForce GTX 1650-vs-AMD Radeon RX 580 8GB
it may be a 6 core, but its definitely on the low end of 6 core cpu's and im sure some quad cores are more powerful.
game debate is the usual website i use for quick cpu and gpu comparing.
https://linustechtips.com/topic/1201710-cpu-help-needed/#findComment-13655782
 Never heard of them
Probably some company that has no experience with hard ware and is just spitting shit
No it's not ?
It still has *6 CORES* and a VERY good ipc count
Certainly was a really good competitor against the 2600
And it probably has a better imc that 90% of ryzen cpus
Build Log:
https://linustechtips.com/topic/1201710-cpu-help-needed/#findComment-13655790
1 minute ago, TofuHaroto said:
 Never heard of them
No it's not ?
a 2600 is only around $125 and has twice the threads
https://linustechtips.com/topic/1201710-cpu-help-needed/#findComment-13655800
That's not the point here
The point is that a 1650's pair isn't "at least an 8400"
It doesn't work that way
And an 8400 isn't a "low end 6 core" lmao
Build Log:
https://linustechtips.com/topic/1201710-cpu-help-needed/#findComment-13655807
when did i say you need at least a 8400, it really just depends on what your going to use the gpu for.
and i didnt mean to say its a low end 6 core, its 7:30 am and i still havent gone to bed yet.
and i already said that he could skip by on that duo core apu depending on the game lol
https://linustechtips.com/topic/1201710-cpu-help-needed/#findComment-13655830
Yes I know but what I wanted to say is that a "recommend cpu for X GPU" doesn't make sense 😜
Build Log:
https://linustechtips.com/topic/1201710-cpu-help-needed/#findComment-13655838
its recommended if you want to use the most out of the gpu in ALL situations, thats why the recommended is something pretty overkill. people tend to act like if you dont have a $500+ cpu its not good enough.
i find it hard to believe that in most situations you would ever need anything much better than a r5 2600, at least thats the case in the gaming industry.
https://linustechtips.com/topic/1201710-cpu-help-needed/#findComment-13655861
