help with amd radeon software setings im a noob please help make the experance better dont know what to change and stuff, im getting tearing and blurry stuff sometimes. and what monitor should i buy i acidently bought a 60 htz 1440p ips what should i get for optimal upgrade! i want 1440p and love bright coulorfull visuals with no tearing or blurrs! 400 - 600 canadian price range! oh and ram is G.SKILL 16GB (2 x 8GB) Ripjaws V Series DDR4 PC4-28800 3600MHz 288-Pin Desktop Memory Model F4-3600C19D-16GVRB 4 sticks. tuning ram would be nice help to
Edited by SansVarnic
Corrected formatting.
https://linustechtips.com/topic/1201576-help-a-noob-out/#findComment-13654772
Please list your sytem specs, members will need this to help you best.
Quote
WHEN MAKING YOUR POST, ALWAYS:
  • Describe the problem you are having in detail but without rambling. If your post is as long as this one, it's too long.
  • Include your operating system including version and 32/64 bit.
  • Include your entire system specs, including the wattage of your PSU.
  • Tell us which BIOS version you have. Some problems can be fixed by updating to the latest BIOS, so check that there are no updates available
  • Include any software running when it crashes (if applicable)
  • Give full details of any error messages and screenshots if possible
  • Use an informative title briefly describing the error. It's not helpful to see a thread titled "please help" or "Urgent" because most people are better at some problems than others, so may not prioritize your issue, and some people will ignore you completely.
Without these details, we may not be able to help you. To speed up the process, please ensure you have all the details on your post.
 CHRISTIAN MEMBER
https://linustechtips.com/topic/1201576-help-a-noob-out/#findComment-13654831
9 minutes ago, SansVarnic said:
ryzen 3700x 5700xt 16 gig 3600 mhz ram 32gig comin. tuf 570 wifi board 1440p 60 htz monitor, old school hard drive ,example playing witcher 3 garalts armor was see through at the waist and lots of blurr or ghosting when moving , i think the blurr is my monitor? i want 1440p 1ms rs bright colors and sharp image, what monitor should i get? 400 -600 $ canadian. radeon software help be nice to, setings ect.
https://linustechtips.com/topic/1201576-help-a-noob-out/#findComment-13654868
23 minutes ago, mackay_jason said:
... Umm I am pretty sure you are not quoting me.
Your paragraph is difficult to read, sorry not being mean here just pointing out lack of formatting.
Ok so questions on your specs...
CPU - What is it?
ryzen 3700x 5700xt  - which one are you using the 3700 or the 5700?
16 gig 3600 mhz ram 32gig comin. - Are upgrading to 32GB or adding 32GB?
tuf 570 wifi board
old school hard drive - What is the harddrive? old school is a very broad wording.
Quote
Sounds like screen tearing and blurring and some artifact misplacement.
Quote
Hard to say if its your monitor, the problem could simply be your GPU and CPU combination but since you did not list the CPU I cant say.
Quote
Lets try to identify and possibly resolve the cause of your issue before trying to replace anything. You may end up wasting your money for nothing.
Quote
Unfortunetly I cant help you with this, I'm not familiar enough to give advice on AMD software.
 CHRISTIAN MEMBER
https://linustechtips.com/topic/1201576-help-a-noob-out/#findComment-13654904
