Hi,
I would like to ask the community for help. On the example of a film from Linus, I wanted to build a computer in a rack. The company that would make the housing on the laser needs a project in AutoCAD and not 3D that is publicly available for download from the film on the channel yt. Is there anyone who has such a project or would be able to do it? The disc I would like to insert is in the E-ATX format.
best regards
https://linustechtips.com/topic/1201483-rack-computer-case-help-request/
10 minutes ago, xarekk said:
Hi,
best regards
which build in a rack case?
if you use protocase the same company that LTT used they should be fine with the 3d model
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
Just now, xarekk said:
I am from Poland so I will use the services of a company from my country
okay still I'm not sure which LTT rack mount case you are after
35 minutes ago, xarekk said:
Cases from the film where the computer made the rack cabinet, the case had plexiglass on top and the computer was liquid cooled
there are still at least 2 videos with that. you taking about the MC server or his personal rig
