Hi, I am building a new system today and I'm wondering what the best fan setup would be for the nzxt 710i. I'll be using a nzxt x73 360mm aio which I think i will place up front. The case comes with 4 x 120mm fans so ill have 7 fans total including the fans on the aio. I'm thinking of having the 3 fans on the aio pulling air in then 1 at the back exhausting. 1 top fan closest to the front pulling air in and the other 2 top fans exhausting. Would this make sense? or should I have all top 3 fans exhausting?
Any advice much appreciated.
build:
CPU: i7 10700k
Cooler: nzxt x73 360mm
GPU: Evga rtx 2080 super ftw 3 ultra
Motherboard: Gigabyte z490 master
PSU: corsair hx750i platinum
Ram: 2x8gb corsair vengeance rgb pro 3000mhz
Case: nzxt 710i
https://linustechtips.com/topic/1201161-nzxt-710i-airflow/
I just flipped one of my top exhaust to a top intake, so that it blows down into the CPU cooler. Dropped temps about a degree or two when the GPU is under load too.
With an AIO that won't be the case for you. However more intake to the GPU will be a good thing.
Are there fan mounting points at the bottom that you can use to pull fresh air from below and shove it up into the GPU?
https://linustechtips.com/topic/1201161-nzxt-710i-airflow/#findComment-13654356
Sorry for the late reply. There isnt any official fan holes at the bottom however there are holes there which I could possibly cable tie a fan to? I have just built my system and put the top 3, rear 140mm exhausting and the aio fans pushing air into the case for now. Gpu is a 3 slot triple fan so I'm sure it can probably deal with a bit of warmer air from the radiator however cooler is always better so I may install a fan under the gpu.
https://linustechtips.com/topic/1201161-nzxt-710i-airflow/#findComment-13660467
I wouldn't worry about it unless your temps are high. Or if you want to push OC and you run into problems.
https://linustechtips.com/topic/1201161-nzxt-710i-airflow/#findComment-13661533
