What are you putting in it hardware wise? Cutting holes to mount fans can seldom if ever be done properly enough to make it not look like shit. Chances are if you just mount 3 fans you'll be fine.
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/1201021-need-some-help/#findComment-13650823
Also unlike most people i dont care if i have to cut up some holes in my case in order to have some more fan holes for air
https://linustechtips.com/topic/1201021-need-some-help/#findComment-13650833
1 hour ago, Goku1814 said:
I mean you do you, but I'd test beforehand. Likely 3 fans should be perfectly fine with that setup.
Gaming Build:
Peripherals:
Laptop:
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/1201021-need-some-help/#findComment-13650841
