can you screen shot the vm? did you change the template from 7 to vista on creating the vm?
main rig:
CPU: 8086k @ 4.00ghz-4.3 boost
PSU: 750 watt psu gold (Corsair rm750)
gpu:axle p106-100 6gbz msi p104-100 @ 1887+150mhz oc gpu clock, 10,012 memory clock*2(sli?) on prime w coffee lake igpu
Mobo: Z390 taichi ultimate
Ram: 2x8gb corsair vengence lpx @3000mhz speed
case: focus G black
OS: ubuntu 16.04.6, and umix 20.04
Cooler: mugen 5 rev b,
Storage: 860 evo 1tb/ 120 gb corsair force nvme 500
backup
8gb ram celeron laptop/860 evo 500gb
https://linustechtips.com/topic/1200981-virtualbox-help/#findComment-13650674
sorry should of specified. the vm's settings, namely optical.
did you let the iso finish "varifying" at the end of the download? that can give incomplete iso if not.
main rig:
case: focus G black
backup
https://linustechtips.com/topic/1200981-virtualbox-help/#findComment-13650684
just remembered, sometimes an error like that can be caused when you insert the cd after first vm boot/on 2nd or when you install the os, but something stopped it when installing, usually a bad iso would do it, but you said you got from microsoft so doubt its bad one. make a new vm and try again. delete 2nd if it fails.
main rig:
case: focus G black
backup
https://linustechtips.com/topic/1200981-virtualbox-help/#findComment-13650689
1) i couldnt find any settings named optical
2)yes i let it finish
3)i tried remaking the vm and i didnt work and still does the same thing
https://linustechtips.com/topic/1200981-virtualbox-help/#findComment-13650697
ill screenshot my windows 7 box when i can.
main rig:
case: focus G black
backup
https://linustechtips.com/topic/1200981-virtualbox-help/#findComment-13650807
so it was broken? what size is the iso? usually with the windows isos from microsoft, you'll need to let it "varify" after the download or its broked. or the iso is missing files. had a windows 7 iso that would get stuck at a cirtain point installing cause was bad one.
main rig:
case: focus G black
backup
https://linustechtips.com/topic/1200981-virtualbox-help/#findComment-13651299
definatly a bad iso then. missing a lot of files.
main rig:
case: focus G black
backup
https://linustechtips.com/topic/1200981-virtualbox-help/#findComment-13651310
