Hello guys,
i'm new to JS and API requests with JSON, i have this Code:
function GetUser(UserID) {
    var xhr = new XMLHttpRequest();
    xhr.open("GET", "https://reqres.in/api/users/2" , true);
    xhr.onload = function () {
        if (xhr.readyState === 4 && xhr.status >= 200 && xhr.status < 300) {
            alert(xhr.responseText);
            var UserLists = JSON.parse(xhr.responseText);
            return UserLists;
        } else {
            alert("Error " + xhr.status);
    xhr.send();
and this is what i'm getting from the API:
and i can't find a way of getting the values of "data".
can someone help please? the test API i'm using is :https://reqres.in and for the first request ( /api/users?page=2) i was able to get it but now i cant seem to find a way.
Thank you for the help,
João
https://linustechtips.com/topic/1200896-javascript-help-university-student/
You json parse the data into
UserLists
So you can get the data with UserLists.data
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
UserLists
i'm getting this error: image.png.8a514165fd38fde11d385825c1edc4c0.png
i did this:
var UserData = GetUser(UserID);
    console.log(UserData.data.last_name);
Stuff like this is where Javascript gets kinda weird.
Basically, when you have
return UserLists;
it's actually returning to the function defined in
xhr.onload
instead of
GetUser
JavaScript is also an asynchronous language, so you can't necessarily just print the output of a GET request like you would in other languages, such as Python (learn more here: https://www.freecodecamp.org/news/javascript-callback-functions-what-are-callbacks-in-js-and-how-to-use-them/).
There are two ways to solve this: callbacks and promises
Callback:
function GetUser(UserID, cb) {
        cb(UserLists);
      } else {
    xhr.send();
and then:
GetUser(ID, (UserLists) => {
  console.log(UserLists);
Promise:
  return new Promise((resolve, reject) => {
        resolve(UserLists);
      } else {
        reject(xhr.status);
    xhr.send();
and then:
GetUsers(ID).then((UserLists) => { console.log(UserLists); });
or (probably the most preferred way, but requires the function to be marked as async):
async function main() {
    var UserData = await GetUser(ID);
    console.log(UserData);
1 hour ago, JopemartHD said:
can you just explain what is the resolve on the GetUser Function?
Resolve means the promise completed successfully and will pass the parameter (in this case, UserLists) to the .then() function or return UserLists if await was specified.
There's also the reject function, which means the promise ran into an error. You can handle a promise error with a try/catch block (if you're using async/await) or add .catch((e) => { console.error(e); }); to the end of the function call (if you're using .then()).
as you're in a browser i like the fetch API is much nicer to use
const request = await fetch('https://reqres.in/api/users/2')
const { ad, data } = await request.json();
