My headphones are virtual 7.1 surround, just so you know. I usually play fps games like cs go and valorant, but i cant really distinguish the steps and from where stuff is happening, but when im watching a cs video or stream, i can perfectly distinguish them. Can someone guide me trough this pls?
https://linustechtips.com/topic/1200702-problem-with-headphones/
14 minutes ago, rice guru said:
Have you tried turning off the 7.1 surround sound settings and just playing with straight stereo?
I dont know how to do that.
This are my headphones https://www.asus.com/pt/Headphones-Headsets/TUF-GAMING-H3/.
Is it possible that the cable connecting the 3.5mm jack to my motherboard interface is with problems?
Wait are you already connected to my your motherboard and not virtual surround sound USB module? Then Asus is straight up lying to you are you running software to emulate virtual surround sound?
I dont think im using any software, like iCue from corsair right?
Directly from the link you supplied
Now, I didn't have to speak this language to notice the asterisk down the bottom clarifying the surround experience was just Windows sonic support, which is funny considering every audio device has windows sonic support, it's built in to Windows.....
You got played OP.
Sloth's the name, audio gear is the game
I'll do my best to lend a hand to anyone with audio questions, studio gear and value for money are my primary focus.
Click here for my Microphone and Interface guide, tips and recommendations
For advice I rely on The Brains Trust :
@rice guru
- Headphones, Earphones and personal audio for any budget
@Derkoli- High end specialist and allround knowledgeable bloke
You got played OP.
Thanks for the explanation, its portuguese btw. I got them very cheap, is there anyway to fix my problem? because they do very well on the phone, but on PC they are very crappy.
Enable Windows Sonic and disable everything else
@rice guru
