Use lan cables if you want a solid connections.
13 minutes ago, Arika S said:
why is the router in the basement?
otherwise the easiest way would be to run ethernet out the wall, up the side of your house, then back in. so much easier than trying to run it inside the wall
It’s a bit of a complicated housing situation with landlord.
ethernet is kinda tricky and was hoping there’s a better solution. I’ve read about setting up mesh but have seen mixed opinions on it.
