BSOD HELP!
Go to solution Solved by DeadlyDivs,
Guess i might as well buy another ram stick
So i just bought a new ram stick for my laptop that had 4gb of memory stock, it is an Acer Aspire 3 A315-51-31YY so after i installed my ram it showed up and it was detected at first but after some time it caused a blue screen of death which had numerous stop codes everytime it happened(memory management, ntfs.sys etc) So i concluded that the ram was faulty but the thing is after i made sure it was faulty using memtest86 it showed that it had no error, like wtf and one thing that i need clearing up is why does it say 2134mhz shouldnt it be 2133
And also i already tried installing a clean install of windows 10
Any help would be appreciated
https://linustechtips.com/topic/1200244-bsod-help/
That's the same thing
What ram stick ?
So dimms and compatibility  are not the best alot if laptop mobos work with only specific type of memory usually micron chips
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1200244-bsod-help/#findComment-13645412
20 minutes ago, DeadlyDivs said:
Its a Crucial ddr4 2133mhz
Are the timings the same?
Also try the 3rd party stick alone and check
Build Log:
https://linustechtips.com/topic/1200244-bsod-help/#findComment-13645850
Yeah that would be a problem cause the one that came with the laptop is soldered into the motherboard itself and also either way i know the timings or not there is no way to change it or atleast i think there is no way to change it on laptops
https://linustechtips.com/topic/1200244-bsod-help/#findComment-13645973
Alright then we'll do both of them have the same timings ? Like cas latency ?
Build Log:
https://linustechtips.com/topic/1200244-bsod-help/#findComment-13645981
11 minutes ago, DeadlyDivs said:
Im pretty sure that on laptops it will automatically set their timings
No it doesn't work that way
Build Log:
https://linustechtips.com/topic/1200244-bsod-help/#findComment-13646040
Then how do i set it?
You go to your bios and auto set it although with a laptop I doubt you will be able to do it
What timings do you have anyways ?
Build Log:
https://linustechtips.com/topic/1200244-bsod-help/#findComment-13646051
How can i tell if it wont show in the bios?
By looking up the model of the ram lol or just checking the sticker on it
Build Log:
https://linustechtips.com/topic/1200244-bsod-help/#findComment-13646088
Also don't put my answer as the best because people will think it has been answered and won't click it
Build Log:
https://linustechtips.com/topic/1200244-bsod-help/#findComment-13646090
