Reset CMOS.
Did you just turn the frequency to 3600MHz or did you enable the XMP/DOCP profile for the memory?
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1200057-ryzen-9-help-plz/#findComment-13643893
4 minutes ago, Andy3900x said:
I got a ASUS prime X570 pro and 32 gig of Trident Z neo 3600 MHz and I got All together and playin games and everything I Hurd I needed to turn my ram to the 3600 MHz do I did save changes and not it won’t boot to bios idk what to do plz help
Did you just change the RAM to 3600 manually, or use XMP/DCOP to do it?
If you just did it manually by setting the speed to 3600, its likely trying to run at way to low of volts and way to tight of timings. To reset your CMOS (BIOS), reference the pic I pasted. This will get you back into the BIOS at all defaults.
To do this, use a house key, car key, metal coin, knife. Anything metal to jump those pins... That will clear the BIOS.
 If you DID use DCOP or XMP, its possible your chip just won't do 3600...
https://linustechtips.com/topic/1200057-ryzen-9-help-plz/#findComment-13643895
7 minutes ago, Andy3900x said:
I just changed to 3600mhz that’s it .... I will try resetting cmos also do I fo it with the mobo powered down
Shut down the computer, turn off the power supply, unhook the power supply cable, hold the case power button for 15 secs then release, get a flat screw driver and gentle touch those 2 pins. After that, hook the power supply back in then turn on the power supply then go into the BIOS then turn on XMP or DOCCP.
https://linustechtips.com/topic/1200057-ryzen-9-help-plz/#findComment-13643929
Ok now my drives won’t detect it shows all my drives but the only one it will let me try to boot from is a diff drive then my ssd
8 minutes ago, AshRiver said:
Yes then save and restart.
Next time quote the person you want to reply so we can tell you are still seeking for help or assistant or whatever.
https://linustechtips.com/topic/1200057-ryzen-9-help-plz/#findComment-13643968
3 minutes ago, Andy3900x said:
The ssd 120 gig
It does detect your other drives and show your os drive. It only boot UEFI drive with WINDOWS INSTALLED only. If you want to see other drives listed in BOOT PRIORITY on EZ MODE  then you need go to Advanced Mode > Boot > CSM > enable LEGACY and UEFI. Doing this will increase your POST time.
2 minutes ago, Andy3900x said:
Yes. Did you save and restart?
https://linustechtips.com/topic/1200057-ryzen-9-help-plz/#findComment-13643999
2 minutes ago, AshRiver said:
What did you change in the boot order? Did you enable CSM LEGACY + UEFI support in the BOOT tab in Advanced Mode?
This is Windows corrupted issue.
I thinks is something about the boot Manager is on a drive that I don’t have the os on is says that is on a 500 gig hhd
https://linustechtips.com/topic/1200057-ryzen-9-help-plz/#findComment-13644032
Oh, how did you install the os? The boot manager partition should be on your 120GB SSD not that 1TB HDD. I think you mess it up during your os installation. Can you try disconnect all your drives except your 120gb ssd to see if it is booting? If your ssd cannot boot alone, but can boot with your 1TB HGST drive then you need to move the boot partition from that HDD to your main 120GB SSD. You can do that on another computer but require this adapterif you don't have another desktop https://www.amazon.com/StarTech-com-SATA-USB-Cable-USB3S2SAT3CB/dp/B00HJZJI84/ref=sr_1_2?crid=1UA8NZT5SAIB5&dchild=1&keywords=external+sata+adapter&qid=1590474175&sprefix=external+sata%2Caps%2C297&sr=8-2
EZ MODE > BOOT PRIORITY should show your 120GB SSD as Windows boot manager not that 1TB HDD.
Your main 120gb ssd should be in sata port 1 then follow the others in order.
https://linustechtips.com/topic/1200057-ryzen-9-help-plz/#findComment-13644041
Ok I’ll but ssd in port 1 and I had it workin fine befor I tryed to change ram spend but I’ll try to figure out what I did before  thanks for ur help but I’m gettin tyrd so I’ll hit u up Tomorrow if it’s ok U have been a lot of help thanks so much
https://linustechtips.com/topic/1200057-ryzen-9-help-plz/#findComment-13644054
Changing ram speed should no touch your drive storages. I think you got the os installation mess up since the BIOS listed your HDD as a Windows boot manager no your 120GB SSD.
https://linustechtips.com/topic/1200057-ryzen-9-help-plz/#findComment-13644061
