Budget (including currency): 700 - 900
Country: U.S.
Games, programs or workloads that it will be used for: Fortnite, Minecraft, Roblox and some video editing
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): No peripherals needed - I'm upgrading from a used prebuilt from IBuypower (Specs -  AMD FX-6300 - R7 250 - Other parts unknown lol) I currently have a 60 Hz Monitor and I am aiming to play Fortnite all epic settings at least 100 FPS - I also am thinking a Ryzen 5 3600 with rx 5700 xt or Ryzen 7 3700X with rx 5600 xt
https://linustechtips.com/topic/1199969-new-builder-need-help/
R5 3600 with RX 5700 XT, the other way is unnecessary for your criteria. Also maybe a monitor upgrade for 100+FPS gaming, you can probably sell your old stuff after you upgrade your system to pay for it.
One more thing, I recommend to wait, the prices and parts availability are not all that great right now.
Gaming With a 4:3 CRT
System specs below
CPU: AMD Ryzen 7 5700X with a Noctua NH-U9S cooler
Motherboard: Gigabyte B450 Aorus M (Because it was cheap)
RAM: 32GB (4 x 8GB) Corsair Vengance LPX 3200Mhz CL16
GPU: EVGA GTX 980 Ti SC Blower Card
HDD: 7200RPM TOSHIBA DT01ACA100 1TB, External HDD: 5400RPM 2TB WD My Passport
SSD: 1tb Samsung 970 evo m.2 nvme
PSU: Corsair CX650M
Displays: ViewSonic VA2012WB LCD 1680x1050p @ 75Hz
Gateway VX920 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@125Hz, 800x600@140Hz
Gateway VX900 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@120Hz (Can be pushed to 175Hz)
Keyboard: Thermaltake eSPORTS MEKA PRO with Cherry MX Red switches
https://linustechtips.com/topic/1199969-new-builder-need-help/#findComment-13643373
Country: U.S.
Come on.......you can't get Ryzen 5 3600 or Ryzen 7 3700x and RX 5700XT with that budget........ Secondly, Ryzen 5 3600 or Ryzen 7 is unnecessary for the stuff you are planning to do with it. If you want to play those, just sell your old PC and wait for a while as new parts are coming out. Thirdly, it's the time of Corona and you should just wait until it's over to go down to your local microcenter and get parts on discount.
If you want to use a PC for those stuff right now, just get something like this
https://linustechtips.com/topic/1199969-new-builder-need-help/#findComment-13643651
Although I recommend waiting for ryzen 4000 CPUs and Nvidia 3000 gpus if you can.
Quote me or mention me at @Shrekpad so I get notified
pc specs:
CPU:
Intel i7 8700K MOBO: ROG Strix Z390-E Gaming RAM: 16GB (2x8) DDR4 G Skill TridentZ 3000 MHz GPU: Gigabyte GeForce RTX 2080 SUPER GAMING OC CASE: Phanteks Enthoo Evolv STORAGE: Sabrent Rocket Q 1TB M.2 NVME SSD,
T-Force Delta RGB 250GB SSD, 4TB Seagate Barracuda HDD PSU: 750 Watt EVGA SuperNova G3 MONITERDell S2716DGR 1440p 144hz G-Sync, BenQ PD2700U 4K 60hz CPU COOLER: Corsair H115i RGB Platinum OS: Windows 10
https://linustechtips.com/topic/1199969-new-builder-need-help/#findComment-13643664
On 5/25/2020 at 10:36 PM, GiftedNovaHD said:
Come on.......you can't get Ryzen 5 3600 or Ryzen 7 3700x with that budget
I finished a PCPartPicker list that I think proves you wrong
A PC that will look ballin' while being very productive (I already have a PSU) for well under my budget and reusing my HDD will aslo save some money.
https://linustechtips.com/topic/1199969-new-builder-need-help/#findComment-13648794
Good game
https://linustechtips.com/topic/1199969-new-builder-need-help/#findComment-13655870
