A little more information would be helpful:
- Where do you enable HDR? Within Windows 10 or in a game?
- Is your monitor HDR capeable? Which monitor is it?
- Did you enable HDR on your monitor?
- Which graphics card are you using?
- Are the drivers up to date?
5 minutes ago, Eric Kazer said:
Wondering if the old I7-3770 has something to do with it.
Unless you're using its iGPU, no. That issue is somewhere between your GPU, cable and monitor.
Windows does have HDR problems in general, the only OS with relatively flawless HDR implementation is macos
Primary PC:
PSU tier list
How many watts do I need?
To sum this up,
Nvidia Driver 445.87
50" LG TV 4k and HDR Compatible
HDR enabled in Windows, could be problem
HDR auto enables on monitor because HDR logo chimes on screen
Using GTX 1660 with 445.87 Nvidia driver
I doubt that the cable is an issue, it's probably a Windows thing.
