my laptop (core i5 10210U) says it can go up to 4.2ghz but when i play games it only runs at base clock (1.6ghz) sometimes the framerate is fine around 70fps for rainbow 6 siege but sometimes it lag and be less than 30fps (this is the lowest settings) how can i fix this problem? the base clock things also applies to most games i play
laptop specs
CPU: i5 10210U
RAM: 12GB
GPU: nvidia mx250
Storage: 240gb SSD + 1tb HDD
https://linustechtips.com/topic/1199227-bottleneck-irdk-pls-help/
Thermals perhaps? Or power plan? Laptop CPUs have a bad habit of never boosting, you should download XTU to see what the behavior of the CPU is like.
Primary PC:
PSU tier list
How many watts do I need?
Yeah, most likely overheating, try using XTU to see.
F@H [] Autobiography []
Main Desktop and Folding Rig :
Cpu : I5-9400f
Gpu : GTX 1070 Founder's Edition
Psu : Seasonic G-650
Ram : G.Skill Aegis 4x8gb DDR4 2666MHz (14-15-15-34)
External Storage : 8tb Western Digital Elements Usb 3.0 Hard Drive
Storage : Samsung 970 Evo 500GB
Motherboard : ASUS B365 Pro-4 m
Gaming Laptop :
Cpu : I7-8750H 2.2ghz
Gpu : GTX 1070 Max Q
Psu : laptop b r i c k
Ram : 16gb 2666Mhz
Storage : 512Gb SATA SSD
Motherboard : it's a laptop.....
old boomer (currently non-functional)
Cpu : I5-6400 2.7ghz (doesn't have a heatsink)
Gpu : Asus RX580 8gb (might sell)
Psu : EVGA 500 watt 80 plus
Ram : 16gb DDR3 1400mhz
Storage : 1tb Toshiba HDD (currently in main pc)
Motherboard : Generic ASUS pre-built motherboard
