8 minutes ago, Greatestfoe said:
I think your right but I’m not sure why the case would have it, I’ll try to follow the wire and see where it goes
probably to some sort of ligt or fan controller or just the front panel lights.
-> Moved to Cases and Power Supplies
As said, thats molex connector. And looking at Corsair's manual, it most likely powers fan hub included with case. Though you must have older case as current ones use SATA. Here's the connector and which pins are still there:
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
