Temps - its gotten up to 100c and past before too like 103c
This is when i'm gaming
I have a Dark Rock Pro 4, should I reseat the cooler? I put it on like I have with every other build so idk what I did wrong if anything. Ive built many PC's in my time but never had this issue.
Is the cooler not good enough for this CPU? or what should I look at to see if I did anything wrong
See my blog for amusing encounters from IT workplace: http://linustechtips.com/main/blog/585-life-of-a-techie/
https://linustechtips.com/topic/1198693-cpu-running-hot/
that cooler beats most of 240mm aios.
try  to reseat the cpu cooler and put new thermalpaste. my 3700x runs much lower with stock cooler
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1198693-cpu-running-hot/#findComment-13634014
2 minutes ago, gloop said:
A drp4 should be plenty for a 3700x, try reseating and reapplying thermal paste.
Will do, I have some arctic silver 5 that I used or should I use the stuff that came with it? I don't think it matters but idk.
Should I maybe use more paste this time? I did the pea size like always
https://linustechtips.com/topic/1198693-cpu-running-hot/#findComment-13634024
The thermal paste shouldn’t matter, the silver 5 should in fact give you better temps I think.
id stick with the pea size and just reseat the cooler, then monitor temps again.
https://linustechtips.com/topic/1198693-cpu-running-hot/#findComment-13634032
Did you pull off that plastic sticket on the base of the cooler?
And if your coverage is good, no need for more thermal paste
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
https://linustechtips.com/topic/1198693-cpu-running-hot/#findComment-13634071
