Popular methods to try and fix stuck pixels are “massaging” the area around the pixel or applying pressure to it.
However, many also say that those methods could create more stuck pixels instead of fixing it.
I had a monitor with a green stuck pixel and tried all methods that I found. Never fixed it.
In summary, according to what I read around for months and my own experience you can either: fix the problem, worsen it, or nothing will happen.
My personal advice is not to touch it and you will eventually get used to it. Otherwise see if you can still RMA the display.
CPU: Ryzen 7 9800X3D Cooler: Noctua NH-D15 Black Mobo: Gigabyte X870E Aorus Pro GPU: Sapphire Nitro+ 9070 XT RAM: G.Skill 2x16GB @ 6400 MHz SSD: PNY XLR8 2TB PSU: Corsair RM1000x Case: Fractal Design North Monitor 1: Asus XG27AQWMG(280Hz) Monitor 2: Asus VG259QM (240Hz)
I usually edit my posts immediately after posting them, as I don't check for typos before pressing the shiny SUBMIT button.
Unraid Server
CPU: Ryzen 5 7600 Cooler: Noctua NH-U12S Mobo: Asus B650E-i RAM: Kingston Server Premier ECC 2x32GB (DDR5) SSD: Samsung 980 2x1TB HDD: Toshiba MG09 1x18TB; Toshiba MG08 2x16TB HDD Controller: LSI 9207-8i PSUCorsair SF750 Case: Node 304
https://linustechtips.com/topic/1198045-fixing-a-stuck-pixel/#findComment-13628870
You can try this. Ive had it work and not work for me on different monitors so its hit or miss it seem
https://www.jscreenfix.com/
See my blog for amusing encounters from IT workplace: http://linustechtips.com/main/blog/585-life-of-a-techie/
https://linustechtips.com/topic/1198045-fixing-a-stuck-pixel/#findComment-13628879
I’ve used this before and it fixed the one stuck pixel on my old aoc monitor
14700k
Thermalright frozen prism 360mm aio
B760 Aorus elite ax ddr5
32gb ddr5 G skill s5 6000mhz CL30
2tb wd black gen 4 nvme
2tb Solidigm P41 plus
2tb seagate hdd
Pny 5070ti
Fractal Ion 2+ 860watt platinum
Thermaltake View 380
AW2725DF 1440p 360hz oled
Aoc Q27G3XMN mini led
Ps5 Pro
Series X
https://linustechtips.com/topic/1198045-fixing-a-stuck-pixel/#findComment-13631506
