Hi people , just wondering if anyone else's experiences are the same as mine.
So when ryen 3000 launched i bought a 3600 non x , and plonked it into my asus b350 prime and it worked perfectly blah blah blah just felt the motherboard needed updating as it didnt have some features i wanted.
I then purchased a MSI B450 pro carbon ac , plonked in the 3600 with the approiate bios and it worked perfectly , shocker i know right ? Overclocked memory to 3800 mhz everything is golden.
However the issue's arrived later after a few bios revision's , i got greedy and tried going past 3800 mhz on the ram and then i had a system crash that was unlike any other before , it was really hard to even get it to boot , but once i worked it out and got back to setting my 3800mhz profile back up , but the bios just ran super slow and un responsive to inputs. A couple restart's later everything is back to normal , still running 3800mhz , but know i have audio issue's popping and crackling , random restart's when playing games , literally as if someone walked in and hit the reset button , boots back up fine though.
I should mention stability test all pass no problem stability isnt the issue , but i think either my motherboard has taken a turn for the worse or the bios is corrupted in some way.
Specs
Ryzen 3600
16Gb Patriot viper steel 4400mhz
Msi b450 gaming pro carbon
Vega 64
EVGA GQ 750w power supply
Blah Blah Blah
Thanks for taking the time to read !
https://linustechtips.com/topic/1197992-odd-motherboard-behavior-ryzen/
