Hello I want to buy the XFX - AMD Radeon RX 5600 XT RAW II PRO 6GB GDDR6 PCI Express 4.0 Graphics Card and put it in the b450 tomahawk max but the compatibility list doesnt have the card listed I know that these are just the cards they tested but does anyone know if it will work
https://linustechtips.com/topic/1197639-compatibility-issue/
It should work It could just be that since b450 came out way before the 5600xt it doesnt show up as compatible
https://linustechtips.com/topic/1197639-compatibility-issue/#findComment-13625837
Graphics card are interchangeable as long as they are using PCI-e. There is no need for them to be compatible with a specific motherboard. The PCI-e standard does dictate that already. As long as your power supply can handle the graphics card you will be fine.
https://linustechtips.com/topic/1197639-compatibility-issue/#findComment-13625856
