First PC Build!
Solved by Derrk,
overall build sounds reasonable. you probably want to add a large capacity hdd along with the ssd, especially with how big modern games can be
only compatibly issue would be the b450. I don't know if this asus board comes with the latest bios already on it, so you may need to flash the bios before it'll work with the 3700x.
these components should fit fine in this case.
stock cpu cooler is okay, but a cheap air cooler will perform better. IMO, the more fans the merrier! but i'm also a bit over-compulsive about thermals
