Help Needed in Android Studio
So in the Android Studio while writing code ,
I want to know how to enable the code helper that I have highlighted in the image
I think I disabled it unintentional while messing with some settings .
if ctrl + space doesn't work then try to disable power save mode in File->Pover Save Mode
ಠ_ಠ
