Hello people! what is a good and quiet air cooler for AM4 for around 30-40 euros.
Specifications:
MOBO: AsRock B450 PRO4
PSU: some kind of Corsair 80+ bronze
CPU: AMD Ryzen 5 3600x
GPU Radeon RX590
RAM 16 GB G.skill Ripjaws 3200mhz
Fans: Xilince and Aerocool
https://linustechtips.com/topic/1196705-best-cooler/
Just now, Shimejii said:
Your not going to find one :P The stock coolers are fine enough
yeah my is loud thats why im asking
Specifications:
GPU Radeon RX590
https://linustechtips.com/topic/1196705-best-cooler/#findComment-13618594
check the cooler performance tier list in this forum. start from tier 7 going up. get the highest tier one that fits in your budget (and in your case).
Please give kudos if you find someone's reply helpful 😃
In case you wonder about my forum name, it's either Cthulhu or two dwarves about to make out ;)
Now that you've seen it, can you unsee it?
Get motion sickness playing FPS =(
"You so ugly you scaring away the fish!"
>>> "BOOB JOB" <<<
Ryzen 3600
MSI B450m Mortar Max
2 x Corsair low clearance DDR4 8G 3200MHz C16
GeForce GTX 780 Ti (temporarily downgraded)
Silverstone FT03
Samsung EVO 2.5" SSD 500G (boot) + WD SN550 1TB (game lib)
WD Elements 3.5" HDD 1.5T (storage; pulled from an old external drive)
Seasonic SS-660XPII 660W 80Plus Platinum Ver II
DeepCool Gammaxx GT (CPU)
Silverstone AB120R (intake)
2 x Silverstone AP81 (intake)
Silversrone FN121-P (exhaust)
AG AGON AG323QCXE (What a hidden gem)
NiZ Plum Electro-capacitive Keyboard
Logitech G703 Hero Lightspeed
Koss Sporta
Windows 10 Pro
Linksys WRT1900ACS (rocking OpenWrt)
WD Elements 5T external HDD (network backup drive)
https://linustechtips.com/topic/1196705-best-cooler/#findComment-13618618
Well if you really feel the need to upgrade your cpu-cooler (which is not necessary unless you want to overclock your cpu (for which you need a good overclock-capable motherboard aswell)), then the „Coolermaster Hyper 212 black edition“ would be your best bet. It boasts an amazing bang-for-buck price for amazing performance. The only thing to watch out for, when buying the „CoolerMaster Hyper212 Black Edition“, is the coolers hight. Most cases wont be able to fit this cooler inside. CPU-cooler Height: 158.8mm
https://linustechtips.com/topic/1196705-best-cooler/#findComment-13618636
What cpu, case, and ram are you using?
https://linustechtips.com/topic/1196705-best-cooler/#findComment-13621177
I have a SuperMicro server case, Ryzen 5 3600x and 16 gb G.skill Ripjaws 3200mhz one stick
Specifications:
GPU Radeon RX590
https://linustechtips.com/topic/1196705-best-cooler/#findComment-13622399
Which case? How much clearance is available for the cpu cooler height?
https://linustechtips.com/topic/1196705-best-cooler/#findComment-13622440
I dunno, like 15-20 cm
Specifications:
GPU Radeon RX590
https://linustechtips.com/topic/1196705-best-cooler/#findComment-13622449
Can you make sure? Most good coolers are 160mm tall.
If there's 155mm of clearance, the Gammaxx 400 is a very affordable option: https://www.1a.lv/p/deepcool-gammaxx-400-universal-cpu-cooler-xdc-gammaxx400/1adr
If it's only 150mm, the Freezer 33 eSports One is a bit more: https://www.1a.lv/p/arctic-freezer-33-esports-one-green/10rp
If you have 160mm of clearance and don't mind spending more, the Phantom Black would be quieter: https://www.1a.lv/p/gelid-phantom-black-120mm/7x67
https://linustechtips.com/topic/1196705-best-cooler/#findComment-13624752
how do you know my main website?
Specifications:
GPU Radeon RX590
https://linustechtips.com/topic/1196705-best-cooler/#findComment-13626733
I don't know many other Latvia shops.
https://linustechtips.com/topic/1196705-best-cooler/#findComment-13626832
ok cool! I think you can close it now! thanks!
Specifications:
GPU Radeon RX590
https://linustechtips.com/topic/1196705-best-cooler/#findComment-13630037
If you found your solution, you can select a post and click on the 'Mark as Solved' button.
https://linustechtips.com/topic/1196705-best-cooler/#findComment-13632208
