Budget (including currency): $1000
Country: United States
Games, programs or workloads that it will be used for: Borderlands 3,Doom Eternal, Battlefield 5, Arma 3,Division 2,Destiny 2
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): Looking for 120 or higher fps on most games at 1080p as i have seen its possible with this budget but i dont wanna pick terrible parts,i would also use it for light work using office which isnt alot of load on the system so ill focus on gaming
Currently using a asus tuf fx505dt so i need a decent desktop to have for home gaming/work any tips would be appreciated since reddit just rips into me :/
No monitor or anything like that for this build ive already looked into that just looking for desktop build
The Look im going for is red and black but i can get cable sleeves in the future
https://linustechtips.com/topic/1196060-first-build-tips-budget-1000/
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  ($184.99 @ B&H)
Motherboard: Gigabyte B450M DS3H Micro ATX AM4 Motherboard  ($74.99 @ B&H)
Memory: Team T-FORCE VULCAN Z 16 GB (2 x 8 GB) DDR4-3000 Memory  ($62.99 @ Amazon)
Storage: Pioneer 512 GB M.2-2280 NVME Solid State Drive  ($69.98 @ Amazon)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  ($58.98 @ Newegg)
Video Card: Sapphire Radeon RX 5700 XT 8 GB PULSE Video Card  ($394.98 @ Newegg)
Case: Corsair SPEC-01 RED ATX Mid Tower Case  ($48.89 @ Amazon)
Power Supply: Rosewill Capstone 550 W 80+ Gold Certified Semi-modular ATX Power Supply  ($85.99 @ Newegg)
Total: $981.79
Generated by PCPartPicker 2020-05-17 23:19 EDT-0400
