Hi guys, these are the specs for my new build I’ve recently canceled my order for the asrock mobo and purchased this instead  https://www.amazon.com/dp/B07T4M3RTR/ref=cm_sw_r_cp_api_i_guzWEb2T1RK0Y
is this going to be better than the asrock? I’ve seen some people saying that the vrm temps are very bad when paired with the 3900x but I’ve also seen people say that there is nothing wrong and it’s perfectly fine so I honestly have no clue. I could use some help thanks!
https://linustechtips.com/topic/1195937-motherboard-help/
4 minutes ago, Ashhez said:
that was out of stock the second i tried to purchase it https://www.neweggbusiness.com/product/product.aspx?item=9siv2g29yy1940 hows this?
That's a bit expensive. Just get this - https://www.neweggbusiness.com/product/product.aspx?item=9siv2g2av15114
It's one of the best X570 boards on the market.
https://linustechtips.com/topic/1195937-motherboard-help/#findComment-13612912
i ended up ordering this one even tho it was over priced and my build will be all white anyway https://www.neweggbusiness.com/product/product.aspx?item=9siv2g29yy1940 thank you guys so much i needed help bad and i really appreciate all your replies!!! THANK YOU SO MUCH!!!!!
https://linustechtips.com/topic/1195937-motherboard-help/#findComment-13612930
