Hey everyone! Thanks in advance to whoever will answer my desperate question. I am a high school student so the budget is pretty low, but at the same time I really want to play with my friends. Since I needed a pc for school in the same period bitcoin mining exploded, I opted for a ryzen 3 2200g build, with 8gb of 3000mhz corsair ram, 500w corsair psu, gigabyte ab350 gaming and spare hard drives i stole from old pcs. The purpouse of this build was to get a low cost, decent pc fast (not necessarily for gaming) and upgrade it later. I saved money where I could, so I don't have an ssd or gpu. I now have a budget of around 200$ and I don't really know if I should go for a 120gb ssd and an rx 570 4gb. Maybe there are deals somewhere I'm not aware of, or maybe I'm thinking this all wrong... Please help!!
https://linustechtips.com/topic/1195825-entry-level-gaming-upgrade/
35 minutes ago, Italian_boy_ said:
OK so you think with this setup I can at least get close to 1080p 60fps mid-low presets on warzone?
Definitely not. I don't know much about integrated graphics, but Warzone recommends minimum of a 1600x, 1660/570, 12gb ram, and you have a worse CPU, no dedicated graphics, and 8gb of ram. If I had to guess you'll have a very hard time running the game.
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
IMO, if you add in a rx 570 you should be able to run at 1080 60fps territory. You may, however experience some microstuttering with your cpu.
I won't be able to run it even with a 570 8gb? And if the dedicated graphics isn't the problem anymore should upgrade the ram or the CPU first?
Both.
Built a mid-range game-cruncher to run MS Word and Chrome because doing anything else just wouldn't have felt right. I've got 250 Watts of power that I don't need, 24 Gigabytes of RAM that I will never use, 8 unemployed threads and I'm happy.
