Help on Network error - 0x80070035
Go to solution Solved by sixmoresoba,
FINAL NOTE - to whoever would have problems with network connectionbetween windows 10 and mac - (my version was High sierra) refer to this post conversation:
Final settings:
on mac side
smb was enabled //AFP was OFF - fix your shared users for proper connection
firewall was off
i made my computer name same as my net bios name
must be on same workgroup
Windows side
Refer to my previous post for a lot of settings // and refer to conversation
firewall was also off - enabled all tcp ip sharing options
edited the reg keys like on the post
managed the credentials
must be same workgroup
hope to help anyone in need in the future
Hi Guys - so the set up is networking between my PC and Macbook (as of now i can see and connect on pc and access the files on the shared - inside my macbook) - ( on my pc i can see my Macbook on the network but having this error when accessing it 0x80070035 )
i tried all the fixes i can find on the net - so far i tried
https://thegeekpage.com/fix-windows-10-error-code-0x80070035-the-network-path-was-not-found/
https://windowsreport.com/0x80070035-internal-network/
https://ugetfix.com/ask/how-to-fix-the-network-path-was-not-found-with-an-error-code-0x80070035-on-windows/
and alot of the seems similar... i tried all of those :( and still have the error 0x80070035
Pls help :(
https://linustechtips.com/topic/1195768-help-on-network-error-0x80070035/
First, make sure your Windows PC is set to the private profile:
1. Settings
2. Network & Internet
3. Change connection properties
4. Check Private
Also, you might need to turn off password protection:
1. Settings
3. Sharing options
4. All Networks
5. Check Turn off password-protected sharing
Basically it won't ask to authenticate to the Windows PC when you're trying to access it.
This article could be usefull has well: https://support.apple.com/en-ca/guide/mac-help/mchlp1660/mac
1. Settings
4. Check Private
1. Settings
3. Sharing options
4. All Networks
Thanks for the quick reply - i just tried this (just now)  and still having the error :(
7 minutes ago, Viper9 said:
Just to be sure the issue is you can't access shared files on your Windows PC from your Macbook right?
mac book can access my pc files   //  but // pc can see the macbook on network but cant access files and gives this error 0x80070035
i also recently tried this - https://answers.microsoft.com/en-us/windows/forum/windows_10-files/homegroup-removed-how-to-get-network-sharing-work/01277332-2916-4a68-853a-116696b20743?page=30
the last part :
6.2. Add all PC's IP-addresses and Names to hosts file (C:\Windows\System32\drivers\etc\hosts).
You can check your IP-address and PC's name by opening command prompt (CMD)
For IP-address type command: ipconfig you get line like this: IPv4 Address ………. 192.168.100.101
For PC name type command:  hostname
Write down IP-address and Name of each PC and add those to that hosts file.
To edit copy hosts file to some another location, right click it and use notepad to edit and save it. Replace original file with edited file. Because hosts file is located on system folder replace will ask administrators rights to perform it.
# localhost name resolution is handled within DNS itself.
# 127.0.0.1             localhost
# ::1                        localhost
   192.168.100.101  PC1   # Ethernet
   192.168.100.102  PC2   # Ethernet
   192.168.100.202  PC2   # Wi-Fi
but still not working :(
Oh ok I though it was the other way around. Then the issue might be on your Mac, be sure that SMB sharing is enabled.
Look at this article: https://support.apple.com/en-ca/guide/mac-help/mh17131/mac
yep its enabled
5 minutes ago, sixmoresoba said:
yep its enabled
When you're trying something to fix the issue do you put it back like it was if it doesn't work? Because you could end up with a bunch of settings that has been changed and that would be a nightmare to troubleshoot.
This article could be usefull has well: https://support.apple.com/en-ca/guide/mac-help/mchlp1657/mac
yep im putting everything back thats not neded
ok when i do this windows now prompts me with the dialogue box - use name and pass - but when i enter my credentials - still the error
Well I think you've found your issue, there's something wrong with the credentials. Maybe try to create another user on your Mac?
Or I guess there's an option to allow anyone on the network to see the shared folders without entering creds.
5 minutes ago, Viper9 said:
The issue seems to be that your PC can't translate your Mac name into an IP address. Instead of using your Mac name in the Windows Explorer search bar use it's IP address.
wow it gave different error now its 079
Just to be sure this is how you're trying to access your Mac right?
\\YOU_MAC_IP_ADDRESS
You can either use run "Windows key + R" or typing it in the Windows Explorer search bar.
20 minutes ago, sixmoresoba said:
yep the ip address
You could try to plug both of them directly with an ethernet cable with manual ip addresses in the same subnet.
Windows PC = 192.168.1.2 / 255.255.255.0
Mac = 192.168.1.3 / 255.255.255.0
Then try to access the shared files on your Mac again.
So on the Windows PC type \\192.168.1.3
hmmm i see ok ill try to find my extra cable and see if it will work
18 hours ago, Viper9 said:
There's something wrong with the way you're sharing the files. I would try to remove the share and do it all over again.
i did that and nope i dont have usb to rj45 :( -
and i also changed the netbios name to match my computer name in mac
- then this works - but with error
also now it pings and when i click the network icon it now ask credentials - but when i enter my credentials it loads and gives this new error - 0x80070079
