First build no post
Go to solution Solved by CPT_BEEMO,
1 hour ago, Biggeasy22 said:
I just realized that my ram may be 3600 and I think the board only supports 3200
The RAM will default to the default speed supported by the motherboard. You would have to change the speed in the Bios by enabling the XMP profile. Is the memory you purchased supported on the motherboards QVL?
I'm completing my first build and when I press the power everything lights up but I have a red led on dram and the PC does not post. I'm assuming I have to flash the bios but I'm worried I bricked the motherboard when I jammed the pci e power cord into the CPU power slot. I since switched the wires and I am also worried that I have 1 pci 8 pin in the GPU and took the same wires 6+2 pin and also put that in the GPU.
Motherboard: b450 tomahawk
CPU: ryzen 7 1700
GPU: GeForce 980ti
Psu: powerspec 650w bronze
Memory: trident gskill 16gb(2x8)
https://linustechtips.com/topic/1195405-first-build-no-post/
CPU: Ryzen 7 5800X GPU: Sapphire Pulse RX 9070XT Motherboard: Asus ROG Strix X470-F RAM: Corsair 32GB Vengeance 3600Mhz PSU: Corsair RM850X White
Cooling: Corsair H115i RGB Storage: Samsung 970 Evo NVME (2TB) Case: NZXT H500i White
Keyboard: Corsair K70 Mechanical Mouse: Logitech Superlight 2
https://linustechtips.com/topic/1195405-first-build-no-post/#findComment-13609239
