2 minutes ago, EladkLing said:
These are the steps but idk what they mean.
Honestly if you might now be comfortable updating the bios you don't have to (after all the problem could still occure ) if you can't get to 3600 on both sticks try maybe 3200 or 3400 and see if that works :)
Phone: Pixel 3a (Purple-ish).
Build Log:
The problem is that it won't let me select the second stick. My discord is Ling#0484 if you want to watch me configure it and tell me if I am just dumb.
26 minutes ago, EladkLing said:
This is what my bios shows. It says one is at 3600 and the other is at 2133 and It wont let me select the other one.
I feel so dumb
I'm sorry I didn't notice this but I'm pretty sure it's set like this for both sticks to run at 3600 theoretically all is set but if you are still getting stutters can you tell us your temps
Edit : I feel like I have no brain in my head lol
Build Log:
3 minutes ago, TofuHaroto said:
I feel so dumb
My temps are in the 70s for cpu and gpu. But is there a bottleneck?
For the most part no there shouldn't be a bottle neck between a r5 2600 and a 2060
Can you try a different game and see if the stutters continue
Build Log:
It does, like in csgo its also the same.
Do you have the latest drivers for your GPU ?
Build Log:
Yeah I got geforce experience and installed the latest drivers through that. I also have some amd gpu drivers installed for the gpu I used while this one was in shipment. Should I delete those amd drivers? If so how do I delete them?
Yes you really should delete those amd drivers
Build Log:
I went into the control panel and I deleted amd catalyst control thingy. Is that it?
No it's not but use ddu in safe mode to fully delete your amd drivers not manually uninstalling them
Build Log:
What is ddu and how do I use it in safe mode?
Install ddu ( display driver uninstaller) go into safe mode and use it
If you want here is a video that I found ( random video ) explaining how to do it
Build Log:
30 minutes ago, EladkLing said:
Thanks for the help.
Good luck :D
Build Log:
