Sorry this is my first time using this forum so it may not work the way im intending, I recently upgraded most of my PC, i got an I5-9400f and i have to turn the Intel boost off in the bios or else it freezes during game play about 15 minutes in and i have to do a hard restart. I've had the boost off for about 2 weeks now and i have not experienced any crashes
https://linustechtips.com/topic/1194974-help/
Hello and welcome.
You gotta tell us what you want help with please.
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
https://linustechtips.com/topic/1194974-help/#findComment-13605730
Can you tell us the specs of your build and what exactly is your problem ?
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1194974-help/#findComment-13605744
Okay ill explain in more detail (its gonna be long)
Okay so i re-did basically my entire pc. I got a new motherboard (MSI Z390-A pro) along with a new cpu the i5 i mentioned above. 16 gb ram and a new ssd. i kept my old PSU which is a thermaltake smart 650 watt, and my 1tb hard drive. When i installed everything and booted the computer up for the first time after installing windows everything ran perfectly fine with no issues what-so-ever. When i booted up any game it would run fine with no issues for about 20 minutes until it abruptly froze and resulted in a BSOD or me having to manually restart pc.I tried just about everything i could think of and everything the internet told me. i saw a single post on a MSI website about turning the Intel boost off in the BIOS to stop the crashes, i tried it since i was out of ideas and it worked, i have been running and gaming without issues for about 2 weeks. I am curious as to why this is happening and how i could fix it to turn the Intel Boost for my CPU back on
https://linustechtips.com/topic/1194974-help/#findComment-13605984
It could be bad firmware from msi it self
Build Log:
https://linustechtips.com/topic/1194974-help/#findComment-13606004
Just now, ride114 said:
Okay, so what should i call customer support and try to get another motherboard or can i fix it?
No I don't think you need to call customer support as I said it *could be* not it is
But if it's only a problem on msi boards it could be as I said bad firmware provided by msi
But if it is not affecting performance then it should be fine
Build Log:
https://linustechtips.com/topic/1194974-help/#findComment-13606015
right now its running fine but i am waiting on the new graphics card i got, i am currently running a Old GTX 970
https://linustechtips.com/topic/1194974-help/#findComment-13606020
You kept your hardrive did you reinstall windows?
Also what are the temps of the CPU when you play a game and it freezes? if they are high maybe you did not apply the cooler in the correct way or pu to little,too much thermal paste.
Last but not least there is a slight chance that your PSU is old and tired of that sh1t and cant deliver the power needed for the boost
https://linustechtips.com/topic/1194974-help/#findComment-13606050
while i agree with these
i dont think itll apply to him because another consumer had the same problem so i dont think that two people ended up with a badly applied cooler or a a bad psu
Build Log:
https://linustechtips.com/topic/1194974-help/#findComment-13606068
the cpu temps while under a load was around 60c and from what i can tell the PSU is doing fine. I kept my old Hard drive, but i wiped it and put windows on my ssd
https://linustechtips.com/topic/1194974-help/#findComment-13606070
1 minute ago, papajo said:
Can you be more specific I mean you had an indicator while playing games and the like a few seconds before crushing the temp was 60C or you just saw the temp before starting the game?
I have never seen my CPU tempurature go over 64 degrees celcius while under load. Loads ranging from about 20%-90% CPU usage
https://linustechtips.com/topic/1194974-help/#findComment-13606085
Im thinking it  has something to do with the BIOS but im not sure
https://linustechtips.com/topic/1194974-help/#findComment-13606089
well sorry for stressing this but its very important to be precise and from what you say I can not be sure because 90% usage doesnt mean much unless you mention this:
Have you checked your CPU temp while playing a game with boost enabled a few seconds before it crashes?
https://linustechtips.com/topic/1194974-help/#findComment-13606108
Yea I have my money on that
Edit : holy fuck I typed my mom LMAO
I mean money
I hate my phone
Build Log:
https://linustechtips.com/topic/1194974-help/#findComment-13606146
from the glimpse i was able to see it wasnt anywhere near the tempurature it would need to be to freeze. i dont have 2 monitors so it was hard to do
Either way as I said I doubt it's something wrong from your side
Build Log:
https://linustechtips.com/topic/1194974-help/#findComment-13606198
Download MSI afterburner (you dont have to have a MSI GPU in order to work with it) https://www.msi.com/page/afterburner
And put an overlay for your game, if you dont know how here is an easy short tutorial its really not a big deal
put all those metrics up and print screen while in a demanding point of a game (e.g many NPCs or you at an open field or whatnot)  it will be useful to see the state of your system while doing that and try to check the temps of CPU and GPU before you crush
https://linustechtips.com/topic/1194974-help/#findComment-13606240
