Hard drive
Solved by Kilrah,
You need to use something like Minitool partition wizard, reduce the size of the 2nd partition, shift it right, and expand the first.
That will physically shift all the data that is on the 2nd partition, so it's going to take many hours and since there is a risk for things to go wrong you should backup anything important to another drive first.
kerriya ·
Posted in Cases and Mods0 -
octester ·
Posted in Troubleshooting2 -
DavidPatrascu ·
Posted in General Discussion5 -
1
2
bill well ·
Posted in Peripherals0 -
4
2
Ha-Satan ·
Posted in Networking3 -
1
play_circle_filled
Latest From ShortCircuit:
