is my 500w psu enough for overclocking?
Solved by 5x5,
1 minute ago, Tehqzy said:ive read reviews on it and they seem fine? i got the amazon link here - https://www.amazon.co.uk/CiT-Supply-Bronze-Silent-Certified/dp/B07CPZS9ZZ/ref=pd_lpo_147_t_0/261-1042515-8628349?_encoding=UTF8&pd_rd_i=B07CPZS9ZZ&pd_rd_r=2e49b528-b594-4f9e-aef0-ca2f3ea397e2&pd_rd_w=eiZsX&pd_rd_wg=tBKq5&pf_rd_p=7b8e3b03-1439-4489-abd4-4a138cf4eca6&pf_rd_r=E2RW7S72E4NPFBV8FJJ2&psc=1&refRID=E2RW7S72E4NPFBV8FJJ2
Don't buy based on clueless and fake Amazon user reviews...if you want your system to be safe, buy a power supply with actually functional protections
