Building a computer for CAD/3d modeling
4 hours ago, Chiyawa said:Depends on the software, most 3D modelling software do use GPU, but they may need to install some additional software. If you are using Blender, Blender should have a pre-installed CUDA software that could be activated if you have supported nVidia GPU in your system. If you are using AMD/ATi GPU, then you need to download a blender plug-in from the AMD websites in order to utilised your GPU.
Okay, let's see...
Well, you can check this out. This is what I can come up with, so you can see if it fits to your liking.
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor ($289.99 @ Amazon)
Motherboard: Gigabyte X570 AORUS PRO WIFI ATX AM4 Motherboard ($269.99 @ Best Buy)
Memory: G.Skill Ripjaws V 16 GB (2 x 8 GB) DDR4-3600 Memory ($83.99 @ Newegg)
Storage: Samsung 970 Evo 500 GB M.2-2280 NVME Solid State Drive ($99.99 @ B&H)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive ($58.98 @ Newegg)
Video Card: Gigabyte GeForce RTX 2080 SUPER 8 GB WINDFORCE OC Video Card ($878.00 @ Amazon)
Case: Fractal Design Focus G ATX Mid Tower Case ($62.98 @ Newegg)
Power Supply: EVGA SuperNOVA G3 650 W 80+ Gold Certified Fully Modular ATX Power Supply ($127.98 @ Newegg)
Operating System: Microsoft Windows 10 Pro OEM 64-bit ($142.88 @ Other World Computing)
Case Accessory: NZXT Aperture M Card Reader ($43.95 @ Amazon)
Total: $2058.73
Generated by PCPartPicker 2020-05-17 04:45 EDT-0400
You can play around to see which components suit your needs. Have fun.
Regards,
Chiyawa
Ah okay cool. I typically use fusion 360 but maybe I should try blender. For the meantime thought I will try finding the plugin to work with my rx580.
Wow that is rather close to what I ended up building. I just need to switch to the 2080 super, add a wifi m.2 card, and the card reader and then I have basically the same build.
Thanks for the help
