Not able to enable 144hz
LeDetructor
Hi,i bought a monitor online,the model nuumber is an-238W05H,When i connect it via HDMI on my Gigabyte RX 580 with the monitor.It works but when i enable  144hz in advanced display settings it shows no signal,and resets the refresh rate to 59hz
HDMI cannot handle 144Hz
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
but when i was using a gtx 1060 3gb,i was able to enable it via nvidia control panel
HDMI 1.4+ can go up to 120Hz. All below is 60Hz.
1 minute ago, Glenwing said:
HDMI 1.4 supports 144 Hz just fine.
Since when?
Dual Link DVI and DP are the only ones i know of supporting 144Hz.
2 minutes ago, Praesi said:
Since when?
Well if i want to use 144hz,i should buy a display port cable right?If so which version should i buy for 1920x1080 @144hz
6 minutes ago, Praesi said:
Since when?
Since version 1.3. It's been commonly implemented since around 2016. See section 5 here:
https://forums.tomshardware.com/threads/how-to-connect-to-a-120-hz-display.3268285/#post-20043090
Normaly I would say 1.4
But check your Monitor Manual, i dont know this Monitor.
i was able to set the refresh rate to 100hz with the hdmi but will find a display port 1.2 since that seems to be the one that can supports 144hz
If thats true, thats no general 144Hz support over HDMI at all.
6 minutes ago, Glenwing said:
It's supported on plenty of monitors.
When i used HDMI, that wasnt an Option. But thats some years back.
But hey. I learned something today, which makes it a good Day.
Looks like DP is still the way to be certain  tho. Cant trust some Data sheets and what they claim. Keyword "responstime"
