Budget: 800 usd
Country: u.s
Games, programs or workloads that it will be used for: mostly gaming and having more than 3 chrome tabs open at a time lol
Other details: i have a 2560x1080p monitor and right now i have a pre built lenovo that cant open more than 3 chrome tabs without crashing also i would like to have a 5700xt in the build if possible
https://linustechtips.com/topic/1194649-800-pc-suggestions/
lol
i tried moving stuff around and make a build with a 5700xt but it always reaches $900 or im just doing something wrong lol
Im with the mentaility of "IF IM NOT SURE IF ITS ENOUGH COOLING, GO OVERKILL"
CURRENT PC SPECS
CPU             Ryzen 5 3600 (Formerly Ryzen 3 1200)
GPU             : ASUS RX 580 Dual OC (Formerly ASUS GTX 1060 but it got corroded for some odd reasons)
GPU COOOER      : ID Cooling Frostflow 120 VGA (Stock cooler overheats even when undervolted :()
MOBO            : MSI B350m Bazooka
MEMORY          Team Group Elite TUF DDR4 3600 Mhz CL 16
STORAGE         : Seagate Baracudda 1TB and Kingston SSD
PSU             : Thermaltake Lite power 550W (Gonna change soon as i dont trust this)
CASE            : Rakk Anyag Frost
CPU COOLER      : ID-Cooling SE 207
CASE FANS       : Mix of ID cooling fans, Corsair fans and Rakk Ounos (planned change to ID Cooling)
DISPLAY         : SpectrePro XTNS24 144hz Curved VA panel
MOUSE           : Logitech G603 Lightspeed
KEYBOARD        : Rakk Lam Ang
HEADSET         : Plantronics RIG 500HD
Kingston Hyper X Stinger
and a whole lot of LED everywhere(behind the monitor, behind the desk, behind the shelf of the PC mount and inside the case)
https://linustechtips.com/topic/1194649-800-pc-suggestions/#findComment-13603033
41 minutes ago, Sorenson said:
If you need a whole new build you can do this, while recycling the storage from the old build into the new build:
https://pcpartpicker.com/list/
does your prebuilt have room to upgrade it? Or is it super old?
im giving the pre built to my mom so i cant really use anything and if i wanted to upgrade it it would cost alot
https://linustechtips.com/topic/1194649-800-pc-suggestions/#findComment-13603120
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  ($174.99 @ B&H)
Motherboard: Gigabyte B450M DS3H Micro ATX AM4 Motherboard  ($76.98 @ Newegg)
Memory: Team T-FORCE DARK Z 16 GB (2 x 8 GB) DDR4-3200 Memory  ($62.99 @ Newegg)
Storage: Team MS30 512 GB M.2-2280 Solid State Drive  ($52.99 @ Newegg)
Video Card: MSI Radeon RX 5700 8 GB MECH OC Video Card  ($303.98 @ Newegg)
Case: Cooler Master MasterBox Q300L TUF Gaming Edition MicroATX Mini Tower Case  ($46.02 @ Amazon)
Power Supply: Corsair CX (2017) 650 W 80+ Bronze Certified ATX Power Supply  ($84.99 @ Newegg)
Total: $802.94
Generated by PCPartPicker 2020-05-15 00:04 EDT-0400
https://linustechtips.com/topic/1194649-800-pc-suggestions/#findComment-13603349
