We need more Information than that.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
https://linustechtips.com/topic/1194573-help-please/#findComment-13602496
12 minutes ago, gtxboi17 said:
Hey! what other information would you like?
Make sure you quote us so that we can see responses
Please list the games you're playing and maybe include a pcpartpicker spec list
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1194573-help-please/#findComment-13602534
14 minutes ago, Stargaze obama said:
CPU model? Games your playing? What settings? Single or dual channel ram? How much? Running an OC on anything? Temperature of the parts idle and load? PSU even?
ryzen 5 1500x. rocket league is where im lagging. All high in most settings. Dual channel ram. XMP on ram. GPU temp idle 59 C.
https://linustechtips.com/topic/1194573-help-please/#findComment-13602551
BTW my return expires tommorow to file of the gpu. So would you guys be down to help me find the issue by today. Because in cause it is the gpu i would like to return it Thanks!
https://linustechtips.com/topic/1194573-help-please/#findComment-13602560
reinstalling drivers after running DDU might change things
Primary PC:
PSU tier list
https://linustechtips.com/topic/1194573-help-please/#findComment-13602724
GPU idle temp is a little high, maybe try reinstalling the drivers and reseating the card, might work?
Also what's wrong with airflow for the card to be so warm at idle? What's it load temp, seems too high for a 1070, which model?
What board are you running at any overclocks?
https://linustechtips.com/topic/1194573-help-please/#findComment-13602743
4 hours ago, gtxboi17 said:
um its a mini card, zotac. No overclocks
Quote People or you will not get an answer 99% of the time. So much traffic here. Impossible to track everything.
What are your GPU Temps under load. What are the FPS. Whats the GPU / CPU usage.
Enough Airflow or does something overhead under load?
I see no reason your PC should not handle RL with ease.
You should just start with reinstalling the driver. More than often this is all it takes.
https://linustechtips.com/topic/1194573-help-please/#findComment-13603438
Quote people please, seems odd, reinstall the driver and make sure everything else has drivers too, make sure it's also up to date, if you used a CD to install the drives they are way out of date, go to the website and install them if you haven't reinstalled yet, just something like 1070 drivers, not specific for different brands or sizes, it a generic driver
https://linustechtips.com/topic/1194573-help-please/#findComment-13604303
FIXED ISSUE. THE FANS WERE ON AUTO AND IT WAS A HORRRIBLE MANAGMENT
https://linustechtips.com/topic/1194573-help-please/#findComment-13607240
Hello,
If you are talking about Lag, you should run a speedtest to see if you are having internet problems.
If not, download nvidia experience and download the latest nvidia drivers.
Download furmark and heavens benchmark and see if you have issues.
Last thing if this not resolves, do a fresh Windows 10 1909 version of windows.
https://linustechtips.com/topic/1194573-help-please/#findComment-13608735
