Intel core I736 10QM, Geforce 660m 2gb, 16 gb of ram DDR3 LAPTOP, VS it is very cheap since my budget is 400 i cannot go over 400
https://linustechtips.com/topic/1194205-will-it-work/
As I mentioned before you won't get a better gaming experience with this as the igpu is weaker and the cpu is a bit worse than the i7.
https://linustechtips.com/topic/1194205-will-it-work/#findComment-13599981
1 minute ago, jaslion said:
Yeah that's my recommendation too.
If this works i could mange to get the money
https://linustechtips.com/topic/1194205-will-it-work/#findComment-13600003
5 minutes ago, SaltyET said:
AMD Athlon 3000G 3.5 GHz Dual-Core Processor
There's not really much of a point in buying a CPU with integrated GPU, when you're also buying a separate GPU. You'd be far better off either saving up so you can buy a Ryzen without the built-in GPU, or find a used one on eBay or here on the forums.
https://linustechtips.com/topic/1194205-will-it-work/#findComment-13600015
So what should i aim for when looking for a used GPU?
https://linustechtips.com/topic/1194205-will-it-work/#findComment-13600024
Just now, SaltyET said:
Oh okay, get a used CPU and a good GPU
Yeah, just get a Ryzen CPU without the iGPU in it. The Ryzens with a 'G' at the end, like e.g. 3200G, have an iGPU, whereas the ones without the 'G' don't, like e.g. Ryzen 5 1600 or Ryzen 5 2600.
https://linustechtips.com/topic/1194205-will-it-work/#findComment-13600031
PCPartPicker Part List
Type Item Price
Motherboard Gigabyte GA-A320M-S2H Micro ATX AM4 Motherboard $54.99 @ Amazon
Memory G.Skill Aegis 8 GB (1 x 8 GB) DDR4-3000 Memory $34.99 @ Newegg
Storage Crucial MX500 500 GB 2.5" Solid State Drive $69.95 @ Amazon
Case GameMax Expedition MicroATX Mini Tower Case $27.85 @ Amazon
Power Supply Corsair CX (2017) 450 W 80+ Bronze Certified ATX Power Supply $64.99 @ Corsair
Custom Ryzen 3 3300x $120.00
Custom Used GPU $100.00
  Prices include shipping, taxes, rebates, and discounts
  Total $472.77
  Generated by PCPartPicker 2020-05-14 06:28 EDT-0400
something like this? where i can just change it for used CPU and get a good GPU for 100 dlls
https://linustechtips.com/topic/1194205-will-it-work/#findComment-13600036
