A-RGB help
Go to solution Solved by -rascal-,
6 minutes ago, Joshua Mitchell said:
I'm new to the rgb game an just bought an AIO with 2 ARGB fans and upon arrival I discovered that to control the rgb I am required to plug into a 4-pin (5v, ground) connector. The attached image is what the rgb connector from the fans looks like.
I am wondering if there is a way I can buy an rgb hub to plug these connectors into and then plug that hub into the motherboard via USB so I can use an rgb software. From what I found, such hubs exist but you have to connect them into a 4 pin rgb header to make the addressable rgb work.
Any help/links would be greatly appreciated
The fans are silverstone 120mm ARGB OEM fans
Mobo is prime H270-plus
The ASUS Prime H270-PLUS does not come with any RGB or ARGB (they are two different things by the way) headers on the motherboard.
It wasn't common at the time...and only started to appear on higher-end Z170 or Z270 boards.
ARGB started to pop up on 300-series motherboards (e.g. Z370, Z390).
In your situation, you may need to look for an ARGB controller / hub...
https://linustechtips.com/topic/1194100-a-rgb-help/
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/1194100-a-rgb-help/#findComment-13599181
Something like these:
https://www.coolermaster.com/catalog/coolers/rgb-accessories/argb-led-controller/#Downloads
Quote
Compact and Convenient - A compact size Addressable RGB LED controller that allows you to easily customize your ARGB devices without the need for either an ARGB capable motherboard or software
https://www.msi.com/PC-component/MAG-MAX-ARGB
Quote
The included 1 to 8 LED HUB can manage system lights via the LED effects control button and provides seven different modes of lighting effects.
AMD Ryzen 9000 Rig
AMD Ryzen 5000 Rig
  • AMD R7-5800X
https://linustechtips.com/topic/1194100-a-rgb-help/#findComment-13599200
3 minutes ago, -rascal- said:
Similar. But I'm looking for a hub I can control with software (such as aura) without having to plug into an rgb header on the motherboard
https://linustechtips.com/topic/1194100-a-rgb-help/#findComment-13599206
It doesn't look like your board is supported by ASUS Aura Sync software though.
If I filter by H270, this is what I see...
That, and the controllers that ARE Aura Sync compatible has an RGB / ARGB header that you connect to an available RGB / ARGB header on the motherboard, so it can be controlled through Aura Sync.
AMD Ryzen 9000 Rig
AMD Ryzen 5000 Rig
  • AMD R7-5800X
https://linustechtips.com/topic/1194100-a-rgb-help/#findComment-13599245
  • 1 month later...
I've found out what you mean now and it actually helps a lot so thanks! :)
https://linustechtips.com/topic/1194100-a-rgb-help/#findComment-13716782
