Hi folks聽
Thanks to the great advice I got of some members from this forum I currently have an Asus VG27AQ on order.
My problem now lies in deciding how to connect it to my PC.
To run this monitor at 1440p @ 165hz what cable should i use?
I was going to buy a Display port cable but was unsure since I haven't had to deal with a 165hz monitor before and the specs say it only has DP1.2 on the back not 1.4
Many Thanks聽馃榾
https://linustechtips.com/topic/1193871-cable-choices/
You just need HBR2, or DP1.2 in order to get 1440p165.
Whichever cables came with the monitor should be enough to drive it at the required hertz.
Gaming Build:
CPU: Ryzen 7 3800x 聽 |聽 GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |聽 Motherboard: Asus X570 TUF GAMING-PLUS聽 |聽 RAM: G.Skill Ripjaws DDR4 3600MHz 16GB聽 |聽 PSU: Corsair RM850x聽 |聽 Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo聽 |聽 Cooler: Corsair H115i Pro XT聽 |聽 Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F聽 |聽 Sound: Sennheiser HD 598聽 |聽 Mic: Blue Yeti聽 |聽 Keyboard: Corsair K95 RGB Platinum聽 |聽 Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/1193871-cable-choices/#findComment-13597435
